Oil leak rear of engine....
Hi all,
Anyone to help me diagnose this leak. Picture is taken just by muffler.
Do I need to drop engine to change the seal?
Christian.
Old 05-01-2011, 10:41 AM
Roslin's Avatar
Hej Christian,
Det kan ofte være lidt svært at se hvor olien kommer fra på en 911, da det hurtigt flyder bag ud - måske pga. den varme blæser luft. Hvis olien kommer der bag konsollen kan det være 3 ting : Fra det lille blænddæksel vd mellem akslen, fra pakdåsen ved krumtappen eller blot et sted i samlingen af de to case halvdele.. Mener du kan sænke bag enden af motoren hvis du fjerner potten, konsol og bagerste motor ophæng.. et forsøg værd :-)
Porsche 911 SC 3.0
Old 05-01-2011, 10:59 AM
Tak Roslin (thanks Roslin)
Looks like that it is actually the rear cover with nuts. What is it called?
Old 05-01-2011, 11:04 AM
Roslin's Avatar
The rear console you can see on the back end of the engine is the Engine mount console which is holding the back end of the engine - it is not a cover that can leak oil.
Porsche 911 SC 3.0
Old 05-01-2011, 11:08 AM
Roslin's Avatar
The black steel one with the two nuts ..
Porsche 911 SC 3.0
Old 05-01-2011, 11:10 AM
Eddyvdw's Avatar
Clean it, put some white powder on the engine, drive for a while and you see where it comes from. It seldom is from where the drops are.....
Ed
72 911E Targa (fun car)
BMW 535i Xdrive (work car)
Volvo XC90 Ocean Race (family car)
VW T2 Riviera Camper van
Old 05-01-2011, 01:43 PM
Thanks Ed, Will do!
There is no dripping now that the engine is cold - it only appears when it is at running temperature!
Old 05-01-2011, 01:53 PM
Eddyvdw's Avatar
So it's likely somewhere at the top end of the engine. But then again, a hot engine and thin oil might leak anywhere.
Good luck,
Ed
Old 05-01-2011, 02:34 PM
bcgreen's Avatar
I have the same leak, but it doesn't matter, hot or cold, it still leaks
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 10-17-2013, 06:57 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Could be from the #8 nose bearing, intermediate shaft cover or cam towers. The cover can be addressed easily, the nose bearing requires splitting the case. Cam towers are involved, too
You need to clean the inside of the black box and get all oil out and then look with a flashlight where the oil is coming from.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-17-2013, 08:26 PM
