<insert witty title here>
Christien's Avatar
Replacing early heater cables - which ones?
There are 2 listed in the catalogue, one is 1350mm (901-424-701-04-M74), the other is 1780mm (901-424-701-05-M100). That's a big difference! Which one do I need?
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 10-18-2013, 11:04 AM
I just bought wire at hd pulled the old wire out
Put new wire in connect to handles and flapper boxes
Was done in an hour , do you just not have the sleeves
Old 10-18-2013, 01:15 PM
Christien's Avatar
Sleeves are fine, as far as I know. The wire has broken on each end so it won't reach to the nut connection on the flapper box.
Old 10-18-2013, 03:49 PM
Fleming's Avatar
As a point of reference the 1965-68 early short wheel based cars use a 1750 length. The short one that I had ordered years ago came as 1270 and is not long enough to reach the valve lever on the side longitudinals from the lever just in front of the shift housing.
Is the wire diameter the same for both? if so I can give you a very good deal on the short one I've got.
Old 10-18-2013, 04:09 PM
Christien's Avatar
But if yours is 1270 and the one I need is 1350 then it's not going to be long enough. I might just try the home depot route.
Old 10-19-2013, 07:36 AM
Fleming's Avatar
After you pull it out take a measure and post it here - so if anyone searches these files in the future they will have good info as to what fits.
Thanks.
Old 10-19-2013, 09:25 PM
You can do what I did for a quick fix. Crimp a length of steel fishing leader, (100# plus test) to the heater cable to lengthen the cable.
69 911 2.3Ez
85 928S
Old 10-21-2013, 11:10 AM
