1987 911 parking brake light on
My 87 cab parking brake would flicker ever once in a while but I would then click the brake lever down and I would go out. Now it is on all the time. Does any one know where the brake switch is? Or what might be causing this.
Old 10-23-2013, 08:59 AM
muck-raker
kidrock's Avatar
check your brake fluid level.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-23-2013, 09:05 AM
emac's Avatar
Same issue with me a few months ago. Ended up being the M/C. Replaced due to it bleeding through itself
Old 10-23-2013, 09:30 AM
I am going to do a brake flush tonight and I'll let you know
Old 10-23-2013, 09:31 AM
wwest's Avatar
That's also often an early sign of battery overcharging....
Old 10-23-2013, 09:34 AM
Was it expensive to replace the master cylinder?
Old 10-23-2013, 09:41 AM
emac's Avatar
No but a real pita to change. Don't forget to bench bleed many say you don't have to BUT I say different (just my 2c) if you don't see any brake fluid and you hold your foot down on the brake and the pedal slowly goes down I say M/C
Ernie 81sc
Old 10-23-2013, 12:48 PM
Overcharging
If what WWEST says is true (battery overcharging), check the water level in the battery.
Bob B
Old 10-23-2013, 01:25 PM
