-   -   '78 SC knocking sound at 850rpm (http://forums.pelicanparts.com/porsche-911-technical-forum/777699-78-sc-knocking-sound-850rpm.html)
Hellraiser 10-22-2013 12:08 AM
Hello,
since I have the car, I always had this knocking sound while idling at 850rpm.
sounds alot like a con rod bearing past its lifetime.
but when I increase rpm's to 950, the sound disappears.
:confused:
bh912e 10-22-2013 12:12 AM
Usually con rod knocks increase when engine is revved and quickly become worse. Did you check valve clearance, I noticed if one cylinder has a loose valve clearance it sounds similar to a light rod knock.
tuchan 10-22-2013 02:06 AM
Oil, temperature and pressure all OK?
Hellraiser 10-22-2013 02:10 AM
Hi,
no we didn't check valve clearance yet because the covers
weren't leaking and I wanted to keep it that way for a while :D
but, I guess it's about time now :)
a friend of mine has it too, but only if the engine is warm
(also a '78 SC)
Hellraiser 10-22-2013 02:12 AM
Hi, oil, temp and pressure all perfect ;)
maybe a little bit low at cold startup (3-4 bar)
but normal pressures when warm (1 bar idling and +1 bar per 1000 rpm)
Flat6pac 10-22-2013 04:03 AM
Bad tensioner, chain slap?
Bruce
Hellraiser 10-22-2013 04:27 AM
Hi Bruce, allready had a bad tensioner on another 911, souded more rattling.
thumbdoctor 10-22-2013 04:37 AM
Try disconnecting spark plug wires one at a time. If the noise decays, it could be piston slap, sometimes a tight wrist pin that gets worse when warm. Generally rods and mains with excessive clearance also cause oil pressure problems.
clem911 10-22-2013 05:07 AM
check your heat shield over the cat for broken/ cracked mounts.
Norm Faustino 10-22-2013 05:23 AM
Make sure all the motor mount bolts are tight.
Hellraiser 10-22-2013 05:46 AM
Hi,
the engine was out a few months ago
http://img.photobucket.com/albums/v4...ps5935af04.jpg
no heat shields, and engine mounts were ok.
kodioneill 10-22-2013 06:27 AM
Like the previous poster said loose wrist pin.
oneblueyedog 10-22-2013 07:12 AM
Old intermediate shaft bearing end play? Maybe hunt the answer in the engine rebuilding forums too.
Reiver 10-22-2013 07:55 AM
If you have Mahle nikasil forged pistons they tend to make a knocking sound at cold start until warm, a trait of forged pistons.
Accelerate and the noise goes away.
If you have Alusils it's a dif. issue.
Lapkritis 10-22-2013 08:07 AM
You can get load knock if you drop rpm too low. You'll hear this on even new engines when they're about to stall.
Hellraiser 10-22-2013 08:14 AM
I was also thinking load knock, but 850rpm is normal idling speed.
Unless my ignition or fuel delivery is way off...
Hellraiser 10-22-2013 08:16 AM
How do I know if I have nikasils? :)
Rich Gas 10-22-2013 08:31 AM
This may be a shot in the dark but I had something knocking at low rpm, turned out the POs wrench had screwed up the AC mounting bolts, which loosened, and the AC unit was bouncing while turning...creating a knocking sound. I retapped the bolts... Tightened it down, Knocking gone. I don't run the AC belt now anyway.
Rich
Hellraiser 10-22-2013 09:49 AM
Thanks, but no AC or smog pump present :(
Rich Gas 10-22-2013 10:06 AM
One more shot...my fan pully was not aligned properly as well...I made sure that the shims were in correctly, tight, and not skewed... This was also a source of chatter, knock.
Rich
