matt gineo's Avatar
Did I damage my CDI??
This afternoon I accidentally hit a fuse in my engine compartment with a screwdriver. I only hit it for a split second but it did cause a spark and a tiny bit of smoke. Would this cause any damage to the CDI unit. I have a 76 911, CIS 2.7. It didn't cause the fuse to blow.
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 10-23-2013, 10:25 AM
KNS KNS is online now
You might be alright. When I had my SC I was reinstalling the battery one day. As I was tightening the bolt on the positive terminal the wrench accidently touched the body of the trunk. BIG scary spark and flash. Nothing was fried and everything worked normally.
Kurt
Old 10-23-2013, 10:35 AM
RETIRED
Joe Bob's Avatar
If it whines.......you're good to go.
2012 ML350 3.0 Turbo Diesel
Old 10-23-2013, 10:51 AM
T77911S's Avatar
that fuse does not power the CD. should be ok. does it run?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-23-2013, 10:59 AM
matt gineo's Avatar
Thanks, I'm not sure yet, I'm in the middle of replacing a fuel hose. I'll know by tomorrow. What are the fuses in the engine compartment for?
1962 356 C- sold
Old 10-23-2013, 11:33 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Think about it...the fuse is in the feed to whatever it powers.
If you short the fuse to ground...you have shorted BEFORE the CDI or whatever.
This does not cause power to go through the CDI...it only effects the fuse and the wire leading up to the CDI.
Bob
Bob Hutson
Old 10-23-2013, 11:40 AM
matt gineo's Avatar
Bob
Yup that makes perfect sense to me, thanks
1962 356 C- sold
Old 10-23-2013, 11:57 AM
Engine fuses are labeled as 1, 2, and 3.
1.) blue and yellow (sportmatic optional) wire connected to a solid red which is most likely a switched 12v source.
2.) red with white stripe wire which also gets power from the red 12v switched source then goes to the 14 pin connector and finally to the warmup regulator.
3.) red and black wire which I’m pretty sure gets power from the battery on the opposite side of the fuse and in turn goes to the rear window defogger relay which should have a black, red and two brown ground wires coming from it.
Fuse #3 is the only one that has power from the battery - that's the one you must have touched. Mine powers the rear window defogger that hasn't worked since I bought the car.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 10-23-2013, 12:38 PM
