Engine Sound Deadening Mat '73 911E
I need to replace the sound deading mat in the engine compartment of our '73 911E. As with most owners, ours has "disintegrated." Because our car is an original owner 911 with just 66,000 miles, I'd like to install one that appears more or less like the original mat.
Of the two ("non-foil") mats listed by Pelican (a light and heavy) is there a difference as far as resembling the original? http://www.pelican parts.com/More_Info/911-556-891-01-M127.htm?Engine%20Compartment%20Sound%20Mat%20%28h eavier-weight%20material%29%2C%20911%2F912%20%281965-89%29%20 http://www.pelican parts.com/More_Info/911-556-891-01-M260.htm?Engine%20Compartment%20Sound%20Mat%2C%20L atest%20OEM%20version%20%28lighter-weight%20material%29%2C%20911%2F912%20%281965-89%29%20 Or... if you have another suggestion (source, etc) please let me know. Thanks! Bill
Bill Waite Grand Rapids, MI --------------------- '65 356C '73 911E |
I replaced mine with a black closed foam sheet that I cut to fit and glued in place.
Stock looking? No Functional? Yes
It seems both of those options from Pelican are no longer available. I am also looking for a "stock" style replacement if possible.
Does anyone know of other options besides the foil offerings by Pelican?
Jake 1973 Tangerine 911S 1967 Corvette Roadster - Triple Black |
AutoBahned
dealer like Stoddards will have them - surprised Pelican doesn't
Automotion has OEM look
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Ah, never thought about stoddards....
