What strength of ampere should I use?
What strength of ampere should I use to my Porsche itīs a 930 -77.
The one I got now is 12V 63A but it feels a little gentle. /J |
What exactly do you refer to?:confused:
Are you referring to the strength or size of your battery?
JA |
Depending on which you're refering to, the alternator should be 70 amp. (980 watt) and the recommended battery is a 66 amp/hour. In the U.S. we typically rate batteries by "cold craning amps" (CCA), I think (I'll be corrected if I'm wrong) the least, recommended "cold craning amps" is a 650 CCA rated battery.
Jerry M '78 SC |
Ouups!
Yes itīs the battery Iīm talking about. Thanks for the answers. /J |
Jocke,
From 1974 onwards ... the standard battery was 66 A-h, and the optional one was 88 A-h. |
| All times are GMT -8. The time now is 05:51 PM. |
