1969 Irish Green Paint Question
I have a 1969 911 fully restored and ready to paint. The original color is Irish Green. I know the paint code is 6806. My painter wants to paint the car in a single stage urethane. The various local paint suppliers seem to be shooting from the hip and I am not confident that any of the colors they are showing me are correct. How do I get the correct formula so that I can assure they mix the color right. I have a schedule with the paint booth saturday and would appreciate any help.
Thanks,
John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver
1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green
1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet
Old 10-23-2013, 01:11 PM
Almost Banned Once
sc_rufctr's Avatar
Find an Irish Green car and go and see it in person?
The formula should be very close but so much depends on the guy mixing the paint.
EDIT: Do you have a restoration shop nearby that specialises in older Porsche's?
- Peter
Old 10-23-2013, 02:03 PM
Peter
Hi Peter. I have not found an original car to color sample, but that would be the best way. I did find an old post about a Glasurit formula matched to an original car, but the formula is in base coat/clear coat. I am having that mixed up and sprayed. I will then try and scan it and mix it in PPG single stage. Not sure I am heading in the right direction though.
John
Old 10-23-2013, 02:09 PM
boxster03's Avatar
Get this over to the Early 911S Registry - you will get the info you need - good luck
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 10-23-2013, 06:47 PM
RETIRED
Joe Bob's Avatar
Most paint is following the CA format of base then clear. If you are in a State that still allows single stage it's the better choice for color match.
2012 ML350 3.0 Turbo Diesel
Old 10-23-2013, 06:50 PM
Another suggestion is to post this on the paint and body forum. There are some very knowledge people that own body shops and can respond from their experience.
Good luck
Bob
Old 10-23-2013, 06:51 PM
Cooper911SC's Avatar
I would seek out the most recent Glassurit 22 Line single stage formula!
Many old paint formulas are no longer being supported with the current move to Water Borne paint technology.
Glassurit is still supporting many of the Old formulas.
Their current water borne is 90 Line. I had a pint of GPX White mixed up for a blend on a client car. 1 pint of color was $125.00 + more for the "reducer"
Love the Irish Green. Good luck with your repaint.
Cooper
Old 10-23-2013, 10:28 PM
joefrantz's Avatar
I would contact user 304065 (that is his actual pelican userid)
He knows a bit about Irish Green.
Joe Frantz
73 911 T
Old 10-24-2013, 12:56 PM
(man/dude)
Jonny042's Avatar
If you poke around on the basf/glasurit website you will find a color tool that will give you the color formula.
I have read, however, that the modern formula is "off".
Also apparently you can still buy 22 line - although my local BASF distributor gave me a blank stare.
Would love to hear/see the results of your quest.
Old 10-25-2013, 05:20 AM
