No manual transmission fluid!
Yes, I posted this on the mini board but am desperate for information.
As a long time user of this technical forum, I trust the advice I have gotten.
Bottom line: Mini shop says I drained the transmission fluid instead of engine oil and then added more engine oil. After that we took the car (allegedly with zero transmission fluid) on a 1000 mile trip and several shorter (300) mile trips. along with random around town driving.
Does this make any sense to anyone? Car is a 2010 Mini 6 speed with only about 25K miles.
How far will the manual mini go with ZERO transmisison fluid?
By the way we drove it to the shop because it pops out of fifth gear. That problem predates the "oil change"
Old 10-25-2013, 10:07 AM
French Import
zippy_gg's Avatar
Let's assume your mini engine takes about 4 qts of engine oil. If you did what the shop said you did you would have about 8 qts of oil in your engine. You would know by now as you would likely kill all the mosquitoes in your county and there would be a lot of blow by pressure spewing oil all over the engine compartment.
Also your transmission would likely acknowledge the lack of lubricant after over 1000 miles by making all sort of noises. Does your engine/transmission smell hot?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 10-25-2013, 10:19 AM
actually 5 quarts. And no, no smell. Aside from the (ongoing and intermittent) popping out of fifth, it ran fine for a couple thousand miles.
Old 10-25-2013, 10:26 AM
I can't find any "definitive" answer on how long a manual transmission will run on zero fluid.
However, I am pesimistic on winning this argument with the dealer.
Old 10-25-2013, 10:27 AM
in my experience they'll last about 10-20 miles. When I was a dealer tech in the 80's
Audi rebuilt trans came with no fluid Shop's would buy and install them and send them out with no fluid 20 miles later the tow truck would pick them up
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-25-2013, 10:48 AM
Lots of snow Porsche away
No way did you do a 1000 mile trek and a couple more at 300 with no tranny oil. You would have melted the teeth right off the gears (ask me how I know!)
And as pointed out, you know when y ou try to double fill your oil pretty damn quick!
76 911S
86 GMC K1500
78 XS750 cafe racer to be
79 XS750 because one is just not enough
Old 10-25-2013, 11:15 AM
Checked out
McLovin's Avatar
lol, a trans going for 2,000 miles with no fluid/oil. Yeah, right.
There's no way that could happen, not even close.
I worked at a shop in the 80s, we had a tech who drained a differential and forgot to refill. It was howling and ruined after only a few mile test drive.
Gear oil is kind of important to have in these things.
Old 10-25-2013, 11:36 AM
Functionista
manbridge 74's Avatar
Impossible. Even if your 1,000 mile trip was done at 5mph.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-25-2013, 12:58 PM
it would be good to ask the shop how many quarts of engine oil they drained when diagnosing your problem. They'd need to account for well over 5 quarts of engine oil to support their theory.
Old 10-25-2013, 01:24 PM
Thanks for all the help. The shop did say there was too much oil. From there perspective the evidence was damning. I went by the shop and pointed to the engine oil drain and to the transmission fluid drain. :-) "I have done this before."
The car is still under powertrain warranty. I think they will work with me.
Thanks again.
Old 10-25-2013, 02:10 PM
French Import
zippy_gg's Avatar
Thanks again.
Good to hear that!
Gilles & Kathy
Old 10-25-2013, 10:21 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Assuming you did blunder, wonder if enough residual oil was in the trans to keep it alive? Nooks and crannies, maybe. Angle you jacked it up?
If there is a pump vs splash oiling that may be why it did not cook in short order.
Still cant see between 8-10 quarts in the crankcase not having noticeable side effects.
1981 911SC Targa
Old 10-26-2013, 07:56 AM
Diss Member
Quicksilver's Avatar
This wasn't mentioned so I suspect I know the answer...
Did you do a 1000+ mile drive without checking the dipstick?
If it was checked would you notice if it was way over the MAX mark?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-26-2013, 08:58 AM
and didnt check the dipstick after you refilled it with oil? Plus I would think youd quickly realize your draining the tranny as it would probrobly be pretty clean and very stinky oil
Old 10-26-2013, 01:07 PM
Years ago I forgot to put gear oil in the diff of my RX-7 race car. Lasted a 30 minute practice session and half of qualifying. When I took it apart it was junk, I have never seen gears that color before.
I now always refill things immediately or I put a note on masking tape across the tach.
My son over filled our spec miata by 3 quarts and it smoked like crazy over 4000 rpm, I doubt you could put 5 extra quarts in without smoking.
1986 Carrera Coupe
2006 Carrera S
Old 10-27-2013, 12:12 PM
