-   -   Idling problem 930 -77 (http://forums.pelicanparts.com/porsche-911-technical-forum/77866-idling-problem-930-77-a.html)
Jocke 08-18-2002 05:55 AM
I have done a searching in the forum but havenīt find any similar problem.
Yesterday when I would go for a little drive the engine didnīt start so I start checking both the fuel and ignition but I didnīt found anything wrong.
Little later I try to start it again and this time the engine just sparkling a little bit.... When engine finally running it was idling about 400 rpm, so I push a little on the gas-pedal and then itīs running OK.
A few hours later I start it up and the idle was nearly 2.000 rpm, after that I have check all vaccum-pipes (I think at least), but the problem still remain.
Could it have something to do with the earlier problem when it wont start?
I now it could be the W.U.R or something but I dont now how I checking that.
Please I need help real quick. (the summer is barely over here in Sweden)
"The car is a 930 -77"
Jocke
Jocke 08-19-2002 02:35 AM
If I start the engine without the Air-Box the engine idle as 900-1.000 rpm.
And I dont think itīs the Airfilter because if I take it off the idle is still running high, but as soon as I remove the hole Air-Box the idle is normal..
Strange...
/J
