-   -   Humming sound (http://forums.pelicanparts.com/porsche-911-technical-forum/778843-humming-sound.html)
r_towle 10-28-2013 05:45 PM
Humming sound
So, I have this humming sound.
Not speed related, random and I cannot control when it happens.
It does not always happen when it cold, and after a while it comes on and goes on and off at random.
I can make it stop by hitting the brakes.
So I replaced the front bearings. And ball joints.
Came back the next day.
It vibrates the steering wheel, and the tone does not change like a cv joint or bearing would do.
Here is the odd part.
When I just touch the brakes, just enough to get the brake lights to activate, but not enough to get the brakes to apply, the noise stops.
A friend suggested it may be electrical...
This is a 1984 Carreras convertible with 240k miles...
So I read about the in tank fuel filter sock, and how a warm or hot fuel pump will hum.
I may do that swap anyways just because of the high mileage.
This car has hummed since I bought it over two years ago, and I replaced the fuel pump and fuel pump relay (under the seat) at that time so I would not end up being stranded...
Still humming, and has gotten louder now.
Rich
mlfox 10-28-2013 06:37 PM
Could be a brake caliper piston not retracting, letting a pad drag against a rotor.
Regards,
mlfox
r_towle 10-28-2013 06:47 PM
Thanks,
Checked all of them....
Reiver 10-28-2013 07:21 PM
check everything in your parking brakes.
r_towle 10-28-2013 08:32 PM
Did not change nor stop when I used the parking brake while driving....
r_towle 10-29-2013 05:54 PM
New ideas?
theiceman 10-29-2013 06:38 PM
pad hum . did you you use that anti brake squeel stuff ?
