SMHemmah
hemmah's Avatar
MSD 6201 works - Tach no work & spark plug gap
I installed a 6201 MSD on my 1969 911T and it works fine.
My tach is not operation and I read that is a common problem. I have read that connecting my black/purple tach wire to the distributor (MSD white wire) instead of the MSD gray tach wire will work. Thoughts? There is a diode provided with the install parts. Can this be used with the MSD gray tach wire to get my tach to work?
I set my spark plug gap to 1.45mm This is towards the high end of the gap recommendation. My drive seemed a bit sluggish but close to what I expected. Should I narrow the gap a bit? Suggestions?
Thanks,
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 11-08-2013, 07:14 AM
SMHemmah
hemmah's Avatar
Oh
spark plugs are NGK BP6ES
I kept the original points
Old 11-08-2013, 07:31 AM
