What does this belong to
Can anyone tell me which year this belongs to. And maybe what it is worth.
Thankshttp://forums.pelicanparts.com/uploa...1383023657.jpg http://forums.pelicanparts.com/uploa...1383023677.jpg |
Front anti roll over bar from?
What is the Outside Diameter of the bar? Cooper |
19mm
sway bar
That looks like a rear Weltmeister 19mm swaybar. I have a couple of them. You are missing the drop links, slider clamps, and attachment bolts. It requires special suspension adjustment/sway bar attachment bolts. It will fit in the stock factory chassis mounts or the add on Weltmeister mounts. They hang down a little lower than a factory rear sway bar. Usually used on early cars.
Is it worth $150.00 as is?
A complete rear sway bar setup, new, costs $300 at a Pelican competitor. I would be reluctant to pay $150 for only a bar when I still need to get the rest of the parts.
Thanks for the info.
| All times are GMT -8. The time now is 06:52 PM. |
