1972 911E vin question
Bought a 1972 911E targa, ran the vin numbers and it comes up as a coupe. The tag still has the factory rivets holding it on. Any ideas????
Old 10-27-2013, 04:36 PM
Banned
lets have it,. targa's are 1 and coupe are 0
Old 10-27-2013, 05:36 PM
The vin is 9112200xxx. Weird...
Old 10-27-2013, 07:59 PM
Banned
all three spots the same number? chassis ,window pillar , metal tag
that is a coupe number = 72E coupe
Old 10-27-2013, 08:04 PM
Did the factory ever make a mistake?? I'll check the other tags. I wonder if the nose has been replaced....
Old 10-27-2013, 08:13 PM
Unobtanium-inc's Avatar
Check the other tags -- door, windshield pillar, chassis stamping. Hopefully they match. - Matt
http://www.unobtanium-inc.com
356 Registry 17369
Early 911S Registry
912 Registry, PCA
Old 10-27-2013, 09:34 PM
lateapex911's Avatar
What about the 'secret' one written under the dash??? (IIRC, it's hand written on the chassis under the dash on the right side, but my memory is vague at best)
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 10-28-2013, 01:42 AM
djpateman's Avatar
The production # is stamped into the lower dash frame below the radio opening and hidden by the knee pad. The third digit is coded for coupe=0, targa=1 and Karmann coupe=2.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-28-2013, 10:45 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
I have a bag of factory rivets, so I would not go with that theory.
Old 10-28-2013, 04:13 PM
HarryD's Avatar
There should also be a DOT Compliance Sticker on the driver door jamb with the VIN number as well.
Hopefully, you do not two halves of two cars!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-28-2013, 06:04 PM
rattlsnak's Avatar
On a side note, we have a 78-83 SC car at the shop right now that someone replaced the front clip on years ago at another shop and it shows a '72 VIN there and on the windshield. Cops came out and ran the VIN and its clean and the guy has a title for the car that says its a '72. So, we figure that either someone wrecked the original SC car and had a donor 72 car or more likely, wrecked the 72 and transferred the front clip and VIN plates over to the SC. Who knows?!
Old 10-28-2013, 08:31 PM
The vin on the pillar is 91122101xx, the tag in front is 91122001xx. I think it's a mis-stamp from the factory. They both end in the exact same 3 digits.
Old 10-30-2013, 10:53 AM
Banned
Take some pictures please ..us nerds are able to tell restamp or fakey tags..
whats the chassis stamp say??
I have had a mistake number on a 1969 but this seems weird.
Old 10-30-2013, 10:58 AM
Please clarify for us.
The A pillar has a tag that reads 91122101xx.
The riveted tag in front, on the trunk latch bulkhead, reads 91122001xx.
What does the stamped VIN, located by the lower left corner of the smuggler's box, read?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-30-2013, 01:59 PM
The smugglers box number is the same as the pillar number. 91122101xx
Old 10-31-2013, 07:54 AM
Since the smuggler's box number is the same as the pillar number, then I would agree that the aluminum tag on the trunk bulkhead is a typo. You have two out of three VINs the same--indicating a targa--and one of those two is the number stamped into the sheet metal of the chassis which is the least likely place to have an error.
L.J.
Old 10-31-2013, 08:06 AM
Banned
72E Targa vin reads ..
picture the numbers tags
i have seen some bad restamping on here.
Old 10-31-2013, 08:08 AM
Platinum Member
dad911's Avatar
Yup, post some pics, unless you don't want to know if the tub may have had the vin swapped.
Old 10-31-2013, 10:33 AM
djpateman's Avatar
Well it is not the first mis-stamp I have come across. At least you have two out of three correct, and if the production # is for a targa, then it is three out of four. It should be fully documented though.
Addicted since 1975
Old 10-31-2013, 10:47 AM
