Wiggle test
(1978sc, 193K miles, History unknown) I have just pulled the Pistons off Case is still intact. When I grab the small end of any rod sticking out the side off the case and wiggle it fore and aft, I can feel it, I can actually hear the oil suction as I go back and forth. I've got a feeling that I shouldn't be feeling this much play |
Functionista
With the .008 top ring clearance from the rebuild section I'd say it's time to break out the micrometer/plastigauge.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
you are right
I guess I just wanted to share the pain a bit...
I'm only this far cuz I thought I had dropped a washer in my engine! |
