Cornpanzer's Avatar
Whats the best short shift for my dogleg tranny and what oil should I use in a 2.2?
I need to shorten up the throw of the gearbox in my new 70 S (mmmmm 70S hehehe, I just dont get tired of saying that=) Do I have any options of which one to use? Also, what weight oil should I use in the 2.2? P.O. used Amsoil, but I didnt ask what grade. As usual, thanks for your input.
Dave C
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 08-18-2002, 06:50 PM
Early_S_Man's Avatar
Porsche Crest
I don't recall ever seeing a short-shift kit for a 901-family transaxle. If your right arm is long enough, you might try shortening the shift lever a couple of inches. After you replace the ball-cup, shift-rod, and coupler bushings, of course!
Gear oil??? Swepco 212.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-18-2002, 07:14 PM
Stay away from my Member
campbellcj's Avatar
There are short shifters available for the 901. Two types - Weltmeister makes one that replaces the entire rod and ball-end with a shortened-fulcrum ball, and also a shortened rod. I tried one once, and couldn't stand the short rod, IME. I had to lift my should off the seat in order to get fourth gear.
The other type requires breaking the epoxy bond between your current rod & ball (keep your minds out of the gutter, guys). You then replace the ball by epoxying on one with a redesigned (shortened) fulcrum.
I had one of these on my former 70 car for a while, but again I ultimately didn't like it. The shift throw is stiffer, and although it had a good positive "feel", I also always wondered if there could be a detrimental impact on the shift linkage, synchros, etc. So I removed it. The one I had was made by Target Motorsports; not sure if they are still around.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 08-18-2002, 07:56 PM
rickeolis's Avatar
Porsche Crest
This is the ad in PelicanParts for the Short shift kit for the 901 tranny: They also have the Swepco-
Short Shift Kits:
Reduce the shifting throw when you add the Weltmeister Short Shift Kit by 35%. Kit bolts on with no cutting, welding or drilling.
Weltmeister Short Shift Kit, 911/912 (1965-72)
SH-SSK-9000 $99.50
-Rickeolis-
1986 Corvette
Old 08-18-2002, 08:20 PM
