Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
gumba's Avatar
I made this a bunch of years ago. A 930 caliper piston expander.
Harold
'79 930/DP935
Old 11-17-2013, 05:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #41 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
I have one of those too. Baum tools used to make it. One of my favorite tools.
Kevin L
'79 911SC widebody conversion
'86 Carrera
Past: '87 Carrera "The Unicorn"
Old 11-18-2013, 06:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #42 (permalink)
kodioneill's Avatar
One of my favorite threads thought I'd resurrect to see if there's any new ideas out there.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-27-2014, 11:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #43 (permalink)
moneymanager's Avatar
Hub Cover Puller
Tired of spending ten minutes to pull the front hub covers? Braze on a couple of nuts. Attach threaded rod with drilled heavy weight (I used an old doorknob.) Add second nut at other end. Screw it on and toss the weight about 10 times away from the hub. Hub cover is off. Reverse to replace. KEEP YOUR FINGERS OUT OF THE WAY. This thing will bite you badly.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-27-2014, 12:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #44 (permalink)
Caveman Hammer Mechanic
ClickClickBoom's Avatar
For fender rolling:
Fender rolling
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-27-2014, 12:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #45 (permalink)
Send a message via AIM to brighton911
Bolt style cam sprocket holding tool. From a 2" nipple and common nails from the bin. Fits and works perfectly.
More low tech but effective, Red scotch brite pads stapled on to a regular 3 arm hone. Using liquid soap as a lube and some patience, it was great for deglaze of Nikacil cylinders.
Old 04-27-2014, 03:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #46 (permalink)
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pickup.
Certainly not as esoteric s the previous posts,
but has helped out on numerous occasions.
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-27-2014, 04:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #47 (permalink)
abit off center
cgarr's Avatar
Main shaft tranny nut tool: the big long socket.
______________________
Craig
G2Performance
Old 04-27-2014, 04:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #48 (permalink)
Concestor0's Avatar
Those 2 minute turn turn'n bank indicators are useless, every time I did a 2 minute turn I ended up back on the same heading I started with.
1986 Porsche 911 Coupe
Old 04-27-2014, 05:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #49 (permalink)
abit off center
cgarr's Avatar
Lol can I use that line! That's my little 2" electric backup
Craig
G2Performance
Old 04-27-2014, 05:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #50 (permalink)
kodioneill's Avatar
That's nice welding there!
1982 chiffon 911sc
Old 04-27-2014, 07:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #51 (permalink)
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Subd.
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 04-27-2014, 09:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #52 (permalink)
jm993rs's Avatar
Very very good post !!
Old 04-28-2014, 12:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #53 (permalink)
Packy's Avatar
As a mechanical engineer, this is like looking at dirty porn. So awesome, yet so wrong.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 04-28-2014, 12:42 PM
  Pelican Parts Technical Article Directory    Reply With Quote #54 (permalink)
My main shaft nut tool. 3/4" Proto 41mm socket split on the lathe then extended to the right length with sched 80 pipe. Yep, over kill but wan be used with an impact gun to dissemble, lol.
Old 04-28-2014, 12:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #55 (permalink)
Speed Dog's Chauffeur
Dodge Man's Avatar
Love This
Gotta love this!!! I grew up working on everything and I love these tools people created. I used a lot of old school bearing/drum pullers, etc.. doing my suspension bushings(front & rear)without a torch. My buddy was out of MAPP gas so we made things work. Way Cool!!! Used the brain!!!
Old 04-28-2014, 12:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #56 (permalink)
Cylinder hold down nuts. Finger nuts are exchangeable for the std M10 1.5 or Supertec M10 1.0.
Old 04-28-2014, 01:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #57 (permalink)
aquazulu2's Avatar
Great tools
Very nice thread, never knew it was out there.. Made a smoke machine, the cam sprocket holding tool, thanks for the refresh.
Old 04-28-2014, 06:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #58 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
I would love to have the Dave Kirk valve lash tool, but they seem to be in short supply. I made my own from a story on Rennlist that actually works extremely well.
Same theory as the other pro one, but a little simpler. that is a flat screwdriver tip at the lower left end of the tool. The "V" is 36 degrees. You tighten the adjustment screw and then back it off 36 degrees and lock it in place. the thread pitch is 1mm , so 10th of a revolution or 36 degrees is .1mm.
73 Carrera RS spec 2.7 MFI
03 Saab 95 Aero
01 Saab 95 Aero
90 Chevy PU Prerunner....1995
RGruppe #79
Old 04-28-2014, 07:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #59 (permalink)
abit off center
cgarr's Avatar
Oil bypass kit if you want to do it yourself on an early case!
Craig
G2Performance
Old 04-28-2014, 07:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #60 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
