Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Elombard's Avatar
/\ Karl that is a ridiculously clever idea, absolutely brilliant!
Erik L.
erik.lombard@gmail.com
84 lime green back date (LWB 911R with RS rear flares) hot rod - absolute riot to drive!
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-29-2017, 02:18 PM
BlueWing's Avatar
Just was posting this in Thrasher's Odometer Post:
It was a spring tool that had a hook on the tapered end that I was able to break pretty quick on another project. The business end had a 2 pronged fork shape.
I ground the prongs off and tapered the flats a bit.
I started by just catching the edge of the "wedge" under the crimp until it was able to slide it in deeper. If I were a tech writer it might sound better but...... Than I kind of tilted the tool and moved it sideways around the perimeter. After about 3/4 of the way around I did a second pass. When the lens band was loose I used the tool to pop it off.
I found going about a 1/32 at a time 2x around did the least damage. As you go around it it goes quick you get a rhythm going - pry sideways push into the crimp and repeat.
After I did the repair I popped the rim back on and used a chop stick to bend the crimp back over by using pressure and rotating the speedo.
Terry
Hope it helps.
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 12-29-2017, 03:11 PM
Discseven's Avatar
TY Erik
Karl ~
Current: '80 Silver Targa w /'85 3.2, '79 Anthracite 930
Prior: '74 Carrera. '79 Silver 930. '79 Black 930.
Old 12-30-2017, 03:33 AM
evan9eleven's Avatar
Nothing groundbreaking, but I've made my own versions of gearbox tools. Main shaft socket (no one ever said the shaft couldn't be square!), old clutch center for locking main shaft to bellhousing (still need to weld on some arms) and a 5th-R slider from a 901 box for holding the main shaft in a vice. In the middle is a jig that bolts up to a gearbox flange for testing LSD breakaway torque, which doubles as an arm for testing backlash with a micrometer.
1981 911SC "Minerva"
2004 Boxster S, Seal Grey
The slope is not slippery; in fact it is entirely frictionless.
Old 01-02-2018, 12:38 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, The Republic of California. Land of wine and redwoods.
The question is how do we merge these two threads?
Ultimate Home Made PTools
Gordon
_____________________________________
'71 911 Coupe 3,0L outlawed
<< See my Garage
Old 01-02-2018, 05:13 PM
petercoetzee's Avatar
Location: Cape Town, South Africa (if i buy any parts I ship to US address)
More utility than tool... But converted jack stands to sill stands. Use these literally every day and couldn't live without them. Wish id built in front sill stand points like a rally car. The small diameter "C" is fits on aluminum cross member up front.
Sent from my SM-N950F using Tapatalk
Old 01-02-2018, 08:50 PM
Fleming's Avatar
Torsion bar saddle for hoist
Made these for the two post lift.
They slide onto the lift pads and the cars torsion bars nest into them.
Sure saves on the rear body seams that always got folded over
Old 01-03-2018, 07:23 PM
Steve F's Avatar
Porsche related, but a 912 this time
A crankshaft holder and a timing gear puller....
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP
Old 01-04-2018, 03:56 AM
Engine tray to drop 930 engine still with air injection
Modified 30M wrench to take off front turbo tie rods
Modified ring is to hold the top nut on 930 rear suspension arm so you can loosen on the other side (next picture shows where it goes). The 930 transmission gives you no room to hold that fast even with a box wrench
And the syringe with hard plastic straw crazy glued is to regrease Cayenne Turbo Cardan Shaft
Old 03-09-2018, 01:37 PM
Alan L's Avatar
OK, from L-R;
G/box long socket, gudgeon puller (the nut just clears the gudgeon bore), chain tensioner, cam bolt holder, spring plate adjuster, 2 clutch alignments, shock center spindle holder (slice cut away and inserted/welded slightly deeper to make lug), leakdown plug - from a chopped up spark plug, g/box drain plug (square nut welded on base of bolt head), the bent flat is for getting at the rear dizzy clip (ignore the holes). The last one is for depressing/removing valve springs with the head in place - various interchangeable studs and positions for different heads/geometries.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-09-2018, 05:22 PM
woland's Avatar
This is the extractor I made to take off the injectors from K-Jetronic:
https://get.google.com/albumarchive/106799704896439228817/album/AF1QipOyu_dfGEAlFMuaRFxLR3YeUClly-suFD-vppzG
Then a key to remove the spark plugs obtained welding a socket wrench with an old FIAT equipment
When the spark plug is slack I use this rubber pipe I found at Louis shop to remove it
Slightly modifying a standard Usag key I obtained this fan remover
To use the hydraulic jack saving the oil lines I made this
If the soil is soft I use a steel plate under the tripod
If I need lifting the car higher I stabilize the car with the tripod, the use bricks under the jack, then fix the tripod in a higher position since I can go under easily.
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 03-10-2018, 05:14 AM
Alan L's Avatar
930 brake expanding tool (I am liking the one posted a couple of pages back).
Spark plug tool. The plug socket has a magnetic insert.
Alan
Old 03-10-2018, 10:48 AM
Alan L's Avatar
Hydraulic jack adaptor, Leakdown tool, CIS tool.
Alan
Old 03-10-2018, 11:07 AM
My first three contributions:
Valve adjustment gauge/adjuster:
Oil pressure and MFI fuel pressure gauge...different fittings:
And les pieces de resistance, hideous yet effective: Z-blocks (they work!)
Keep 'em coming! John in CT
Old 04-09-2018, 05:19 PM
AndreasK's Avatar
Made a separate post about this simple way to remove injector sleves. Think it belongs here too
Lengthy description here: A way to remove injector sleves.
I also adapted this to change spark plugs. Haven´t got the original socket, and I dint have time to wait for shipment. Just had to grind down the center section a bit to fit cyl 1 & 6. Worked perfectly.
1977 911s
Old 04-30-2018, 02:39 AM
Slippery Slope Expert
Steam Driver's Avatar
Electricians plastic fuse puller works better than oily fingers for holding rocker shafts when removing/installing. Far easier to hold in line with the bore to get it started in.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 04-30-2018, 05:21 AM
