notfarnow's Avatar
Homemade 911 tools
Show me the contraptions you've come up with for working on your 911
I made a pair of pullers for the front inner & outer bearing races. I welded up some old junk wrenches & some threaded rod. Took me about 30 mins to make. They aint pretty, but they worked like a charm.
They have *just* enough clearance that you can angle them in sideways behind the bearing race, and then pull it tight. the booger welds near the edges keep it from sliding off on either side:
You can kind of see how they are made to catch the very inner edge of the race:
The bit of coathanger was welded on because it makes it easier to get the puller in position under the race, and get the nut etc all in position and tightened
A sacrificial wrench was used for something to tighten the bolt against:
And this is what it looks like in use, on the hub:
and a similar puller for the inners:
Anyway, show me the tools YOU'VE made
'03 Carrera 4s
'00 4Runner / '85 LeCar / '88 Iltis
+ a whole bunch of boats
Old 11-01-2013, 06:39 PM
Rear Spring plate height adjustment tool
Open ended 35mm spanner, which has been grounded down on top, bottom and sides to adjust rear spring plates for height.
Old 11-02-2013, 04:02 AM
BlueWing's Avatar
External Thermostat Wrench
I made this to tighten the oil line to the rear passenger side wheel well external thermostat. It only turns one tooth at a time but fits in there with a good secure fit on the fitting and clearing the rocker sheetmetal. Should fit the other oil line nuts as well.
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 11-02-2013, 07:13 AM
Norm Faustino's Avatar
Now this is a great thread.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 11-02-2013, 07:16 AM
Elombard's Avatar
wow - I want to see more. I have to go look I know I made something.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-02-2013, 07:55 AM
Taking it apart is easy
Jerome74911S's Avatar
I made a gizmo from plumbing parts to install certain seals - I need to find it so I can post photos.
Worked fine.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 11-02-2013, 10:32 AM
Even a Bad day is good
47silver's Avatar
I made a piston pin puller using a long bolts, some nylon bushings from lowers, And a nut to tighten. Use small diameter against the pin, and large diameter against the piston, tighten the bolt and draw the pin out without any stress on any parts.
Old 11-02-2013, 04:27 PM
redturbo911's Avatar
Very cool.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 11-02-2013, 07:01 PM
Chain fence eating turbo
I made a cam holding tool to torque the retaining bolt while holding cam still.
It broke and my cheap ass bought the right tool.
Old 11-02-2013, 07:56 PM
IXjamesXI's Avatar
I had to "make" one today as a matter of fact. The cheaper of the two 12mm triple-square sockets sold by our host is too long for it and a socket wrench or breaker bar to fit in the housing of a P201 engine yoke. So I punched out the roll pin with a drift. Then I shortened it with a high precision CNC lathe.. actually I held onto it with vise grips and just kind of eyeballed it as I cut it with a hand held angle grinder. Then I tried drilling a new hole in it so that I could re-insert the roll pin. No dice.. the bit wouldn't even scratch the thing, it must be really hard. I am contemplating trying to anneal that end of it so I can drill a hole for the roll pin, but I haven't done it yet as I am a little nervous that it might soften the business end of the thing. So in the meantime I resorted to some super tensile carbon based adhesive material (masking tape) to hold the bit in the socket. Worked like a charm.
'82 SC Coupe / Pacific Blue
Old 11-02-2013, 08:27 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Sub'd. - as Norm said
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
Old 11-03-2013, 10:12 AM
For putting those pit vipers of springs back in early window regulators and seat hinges. Needs to be a bit more horizontal than in the last photo, but it's difficult to hold and shoot at the same time! Bit of carpet or similar under the spring to stop it going all the way on until you have the other end latched, then remove the carpet and tap the spring home. Works better than it sounds!
Old 11-03-2013, 10:51 AM
MTemp - Very Cool
That repair is in my near future. Any hints or tips or links you can recommend?
Steve B.
1972 911t
1999 328is
Old 11-03-2013, 11:20 AM
wayner's Avatar
I just finished making this blue thing today. Does that count?
Wayner
I can't wait to see what I do next!...
Old 11-03-2013, 11:57 AM
notfarnow's Avatar
Wayner... any more pics? Was thinking about making something like that... my SC sat right in the middle of the garage for 3 weeks while I waited for parts. Would have been great to be able to roll it to the side. How does it mount to the car?
I'd like to contraptioneer one that works for both the SC and the C4
'03 Carrera 4s
Old 11-03-2013, 03:39 PM
JamesXI
No need to drill in a hardened part, just JB weld it in. Guaranteed not to ever come out.
1986 Carrera Coupe
2006 Carrera S
Old 11-03-2013, 03:45 PM
78-911SC's Avatar
Nice subscribed.
PJ
78 911sc Targa
70 911T
Old 11-03-2013, 05:00 PM
wayner's Avatar
Here you go:
help designing shop stand for 911
Wayner
Old 11-03-2013, 05:10 PM
Originally Posted by sballard View Post
MTemp - Very Cool
See page 10 of my DDK restoration thread. Should give you enough to go on!
It's a 2 man job so get an assistant to knock the end of the spring onto the tang in the hinge while you hold the tension with the bar.
If I was building it again I'd place the pivot closer to the middle of the bar and so make it easier to keep it horizontal and latched while keeping the area around the spring clear of your hands so your assistant can see what they're doing!
Mick
http://www.ddk-online.com/phpBB2/viewtopic.php?f=28&t=33207&start=135
Old 11-04-2013, 02:14 PM
theclaw's Avatar
Sort of a tool. I used a hose clamp to compress the omega spring when doing a clutch job or for replacing the cable.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 11-04-2013, 02:56 PM
