86 ssinit's Avatar
Front seat belt help
How do I remove the rear interior panels so I can install new seat belts. I looked at it and thought I could just unscrewed it but still does not come off. Is there an order of things to be removed to get to this panel. Thanks
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 11-10-2013, 09:31 AM
pitsqrd's Avatar
Take the top cap off with held on by screws. Then lift the rear part of the side panel to disengage the "tongue" from the "loop". It will be more clear once you get the rear of the panel lifted up. Once the tongue clears the loop you can pull back and up and the front of the panel will come away from the B pillar. Just go slow and don't force anything.
Once the panel is clear you will have access to the seat belt retractor.
Hope this helps.
Old 11-10-2013, 10:50 AM
emac's Avatar
Just to let you know a 944 belt can be used, just have to drill the mounting hole on the piller out a bit
Old 11-10-2013, 10:55 AM
