 vibration--still can't find it OK, ongoing symptoms:  when warm, a drone eminates from front end starting at about 65.  Low pitch.  Under light to moderate braking, a vibration (not shimmy) comes through wheel and seat.  Drone and vibration cease with slowing. It comes and goes, which makes it more difficult to pin down. I've done discs all around, pads, lines, fluid, high speed balance. Tires (Dunlop Direzza's that have been tracked) inspect OK. Where do I look next? Some odd bushing somewhere? |
 Front wheel bearing ? Even though you've had your tires inspected, i'd find a buddy so you can swap out the front tires just to verify. |
 More data:  seems to occur after taking fronts off and putting back on.  When it occurs, and after slowing, stopping, parking car for a bit...and then trying to duplicate, it doesn't happen.   I am doing an AX this weekend with both a wheel change at the event and a 60 mile drive to and from. Hopefully will find some more data points. I recently rebuilt the calipers as well. They don't drag when hot or cold near as I can tell (car rolls easily, and when wheels are off, the hubs spin with minimal drag both hot and cold) |
 bearings was my first thought now maybe warped rotors or bent rim. if you have a lot of play in the steering wheel, replace the bushing in the steering column and check tie rod ends |
 Bearings or tires.  I would lean toward the bearings. |
 vibrations You might want to check your front rims by having them rotated and measured accordingly. |
 Is one wheel noticeably warmer that the other? I had a similar situation on a BMW, and after a lot of trial and error measures, I finally discovered it was a sticky caliper that would grab the rotor just enough to start to get the disk hot. Once that started happening it started warping the rotor etc. That problem presented a lot like what you are describing. Good luck!! |
 Take a look at this from over on the 930 Turbo Forum; http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/780083-when-time-new-motor-mounts.html If you can't pinpoint your problem to wheels/tires or other rotating components it gives you another place to check. |
 I had a local specialist wheel shop take the fronts off and spin them; no noticeable bends/warps etc.  I've had the wheels for several years, no curb bashing under my watch.  I've had two set's of tires on them with this problem not occuring.   The brake calipers were rebuilt when I did the rotors/fluids/lines a month or so ago. I did that job because at the track under heavy decel I got a HARD shuddering and the front rotors were at the limit and there was lots of drag on the rotors. My capable tech thinks it's possibly still an old caliper problem, even with the rebuild, considering it is an inconsistent problem. The wheel bearings are adjusted properly and have only 7500 miles on them and 4 years. I'll inspect, but my thinking is a wheel bearing would be a consistent issue or come with some wheel play, of which there isn't any The wheels are not hot under normal driving, nor is there a heat differential. I'm starting to lean tires. |
 wheel bearings will make noise. usually more noise when turning. (left or right) if you have a vibration, look at the lower ball joint and tie rod ends since you have had everything balanced and checked for warpage. what about alignment? not sure if bad toe setting would cause a vibration. have you checked the rears? still sounds like a warped disc |
 Check your parking brake adjustment and shoes inside the rear rotors. If there is the slightest contact with the shoes the car will vibrate after a mile or so then get more pronounced while driving and when you stop and they cool down the vibration disappears. One last point,  the vibration seems to come from the front when this happens. |
 on rebuilt caliper are the piston are 20 degre angle just thought. |
 oooh, I like the parking brake angle.  That would also square with the "changing tires at AX with parking brake set and then getting vibration after 20 miles on way home" scenario I've been experiencing. Putting it up on the rack this afternoon to pull wheels and take a squiz at bushings, etc. Alignment: car tracks true, and turns in crisply when pointed. That being said, it is pushed at times. Worth a look. Cheers |
 I had a similar problem with my truck. It turned out that although the services front callipers worked perfectly, the pistons of bores were beyond tolerance and the piston would be allowed to cock slightly sideways in the bore causing it to vibrate and moan when off the brakes and shimmy when on the brakes. Just a thought. |
 OK, so being up on rack revealed no issues with tie rods, bushings, play, etc.  Tried to avoid setting parking brake. Drove to AX venue 60 miles away this AM at highway speeds. No issues. Swapped tires, drove event, but set parking brake once inadvertently during tire swap. (I have chocks, so it's unnecessary, but habits...) Drove event, no issues with braking, vibrations, etc. Swap tires back. Drive a bit and put gas in car. Start up the highway, 20 minutes into it.. .AAAAAGGGHHHH here it comes again. Car is tracking straight, I try some wheel inputs to see if it changes anything, no dice, I apply a bit of parking brake while under foot braking vibration, I definitely feel more vibration but that feels like it's coming from behind me (a bit different then the shudder in the wheel when I touch the foot brake) I slow down to lesson the vibration, it fades....and disappears for the rest of the 30 mile trip at north of 70 MPH. Man, do I have to a)buy new calipers and try that, and if that fails b) buy new front tires and if that fails c)completely rebuild the hub assembly? (This is of course after I take a harder look at the E brake situation.) The rotors look completely even, and the car rolls easily. I guess it's possible that at speed one caliper is binding a bit. Any other ideas other then the GREAT inputs I've already got, for which I thank you all? |
 Caster? |
 More data:  came back from reputable tech with SSI's and an M and K two into one.  Sweet. More on that in another post. They inspected the entire front suspension and found nothing. Lubricated zercs fitted poly bronze bushings. They found and repaired a spring issue in the ebrake. Today, 40 degree morning, driving to Birmingham for some nuclear family Christmas time (Mom is 86..Woohoo!) Took the back roads to I-20. I get all the way into Alabama before...you guessed it...droning and shaking commences. 25-30 miles later, all is well. Continues that way to destination. Car sits and cools for 4 hours. Depart for the home 'drome, temps now 65. After 10 minutes (pulling onto I-20 from I-459) presto, here we go again. 30 miles later at highway speeds (65-80) it stops. Smooth as glass at up to 90 and down to zero after. As a reminder, discs/pads/calipers new or rebuilt, bearings under 10K and greased not wobbly. I'm starting to think I've got a bad tire. I have tracked and autocrossed these tires. They are two and a half years old and have been in on the car as it sat in an unheated garage with temps occasionally below freezing. Wouldn't a bent rim ALWAYS vibrate, and not go away? Wouldn't an alignment problem ALWAYS manifest itself? AAARRRRGGHHH! |
 It's the tires. I went thru the same thing twice. Just as a side note, I've heard that alignment issues won't cause vibration.  Well they will on a 911. My rear toe was out by a tad and it was annoying. |
 AX is like masturbation.....why would you use race wheels at an AX? |
 Tires. Doyle |
 OK, a few weeks ago I swapped the rear wheels with some donor's drove car, seemed to fix.  So we just put new Bridgestone Potenza R-11a on the car, high speed balanced.  On drive home...drone and vibration develops.  AAAARRGGHHHH! The three and half year old heat cycled out Direzza's needed replacing anyway, so that's OK. This leaves alignment (the car tracks well and brakes straight and isn't twitchy), rear calipers (they release fine), half shafts, front and rear wheel bearing replace (fronts were done less then 10k ago and all are adjusted properly) and half shafts/axles, which co-incidentally were replaced by a shop that did shonky work a few months before this problem presented itself. Any other ideas? This is getting time con$uming. |
 Have you checked the shocks.  I would think that this would occur all of the time and not intermittent. |
 When its happening have you tried to turn hard back and forth to see if it changes when either side is loaded or unloaded? I'm leaning toward a caliper sticking or wheel bearing, but bearings usually make noise. |
 Marc, Yes. I tried that on the recommendation of the tech at Goldcrest. No change in intensity or sound with loading. There is a "rumbling" or "drone" associated with the vibration. And, I can feel it both in my seat and in the steering wheel. |
 Wish you could load her up with brand new (matched) rubber on ALL corners.  If she shows again, then it most probably won't be tire-related.  If still there (and, as you described), I'd make sure the alignments are ON.   This theme of time-based failure is indicative of (possibly) being a heat-related cause (rubber),......I'm still thinking the tires need to be ruled out WITH a NEW set at all corners. Else, it's time to greasy and recheck the very items you (and others) have mentioned. Have you made any progress on this? Best, Doyle |
 Scott, when it happens again very lightly press on the brake pedal while keeping your other foot on the gas to maintain speed and see if it changes. |
 I had my various vibrations significantly reduced when I returned my front suspension to the zero camber setting (required un-lowering my car a little to achieve).  I like the solid feel better, knowing I'm giving up a more stick in the corners.  After years of driving cars with 1 degree of camber, I really like the zero setting for street driving. Chuck.H '89 TurboLookTarga, 373k miles |
 hm. you have a phono that "comes and goes"... strange. nontheless: what about the bearings?!?! did you check that (and their basins too)? if yes HOW did you?! I did, as I hat this similar to your pheno... gone! http://forums.pelicanparts.com/uploa...1394720695.jpg |
 Doyle, I just put four brand spankin' new RE-11A's on, road force high speed balance. Thought "that'll do it" Nope. Half shaft, bearings, and rear calipers are next on the hit parade. |
 TIA. |
 Did alignment and re-pack of the CV's and finally haven't heard or felt for several trips.  Combination of worn Dunlops (not visibly but heat cycling/stress from AX and some track use) plus alignment me thinks. Thanks for all the imputs and ideas. I hope this thread helps someone else. By the way, the RE11's are very good tri-use tires. Sticky enough cold for AX use, predictable at speed on big track, comfy on the street. |
| All times are GMT -8. The time now is 11:08 AM. |
