-   -   Rebuilt DME, It Still Dies! (http://forums.pelicanparts.com/porsche-911-technical-forum/779570-rebuilt-dme-still-dies.html)
larrym 11-09-2013 08:04 PM
so - if you hot jumper the pump - does the car run OK?
fwiw - i had a similar problem awhile back on an engine that had sat in storage a long time - turned out that 3 injectors were stuck - it had the same start-die symptoms you describe
Originally Posted by 99hdtop (Post 7747360)
I did some testing per Bentley manual and ECU Doctors. Using a fused jumper between terminal 30 and 87B on the DME relay plug-in with a on/off switch I was able to test fuel pump. It works fine. But using terminal 20 on the DME plug-in per ECU Doctors, the fuel pump did not work. This method goes thru the DME relay, I think my new relay is bad. What do the wizards at Pelican forum think about my findings?
99hdtop 02-09-2014 03:34 AM
All of the problems with this car turned out to be at the fuse panels. Bad connections from a VR problem I had a while back, things got a little toasty I guess. New fuse panels should fix the problems. Parts are on order. I sure will be glad to get this car going again and staying running. When I do get it running I am going to wring it's neck for being such a pain in the ass for so long!
Joe Bob 02-09-2014 03:44 AM
Told ya......3 months ago.:rolleyes:
Glad you figured it out.....
Elombard 02-09-2014 04:36 AM
Glad you figured it out - what is a "VR problem"?
john walker's workshop 02-09-2014 04:48 AM
i've had bosch silver coils die 2 minutes after install. visually check the spark out of the coil wire.
99hdtop 02-09-2014 06:05 AM
I know you told me Joe Bob, I always had good voltage at the DME and DME relay during tests, so I thought that power supply was OK. I sure got a bunch of new parts on her. She has a name now, after a car or truck leaves me stranded on the side of the road like "Gudrun" did two weeks ago they get a name. She has been named after Heinrich Himlers daughter. Not a very flattering name at all. As an adult she worked to free Nazi war criminals.
99hdtop 02-09-2014 01:51 PM
VR is voltage regulator.
