-   -   Spedometer Question (http://forums.pelicanparts.com/porsche-911-technical-forum/779819-spedometer-question.html)
Kool-aid-82 11-04-2013 07:13 AM
Spedometer Question
I need some advice on my Speedometer.
Running OEM size tire front & back.
Earlier in the rebuild I sent the speedometer off to North Hollywood to be rebuilt...
(the gear had dissolved during 16 years of storage and the unit no longer worked)
I have chased wire and they appear to be good but... while driving it reads about ~30 MPH low.
30 @60, 35 @70
What else could it be?
Bad Sensor?
Flat6pac 11-04-2013 07:44 AM
Inside the trans, on the pinion is a plate with 8 magnets. If one on the magnets drops off you loose 12.5% of your drive.
Standard replacement part and you can pull the pinion in the car. 915.318.045.03
Bruce
Kool-aid-82 11-04-2013 03:36 PM
Thanks that gives me a starting place & searches to dig though.
