79 911 wiring foglight switch
rear window defog and fog lamp switch wire connection . need to know proper order of color wires to connect to these 2 switches. have looked through wire diagrams not all the information is complete these are the colors that go to these switches
brown double wire one connector. single brown wire connector. solid green wire an solid black wire piggy back together.In same wire harness white wire w black stripe. solid black wire. white wire with green stripe. i traced the white wire with green stripe to rear of car/ think this is the rear window defrost wires. solid gray wire an blue wire with white stripe goes to fog lamps. cig lighter 3 post a black w small elbow not sure the other 2 post one has solid green 2 gray green wires connected by piggy back.
almost finish with this rewire have only few areas holding up completion . thank you all for help. four 0 four 372 857 nine
Old 11-04-2013, 03:08 PM
