ignition coil/spark plug wire recommendations
I am new to this board. Just purchased a 75 911. Car needs engine work starting with tune up. The Bosch ignition box has been replaced with a Permatune and the coil is an older standard Bosch blue coil. Looking to replace the coil and spark plug wires. I see many options here in the pelican website. What will be the best coil and plug wires to use with the permatune unit. I've seen some steel braided shielded ignition wire sets offered here. Are these compatable or can I go with others listed here on pelican.
Old 11-05-2013, 06:10 PM
