Disabling the O2-sensor
My question
Why is it not possible to have the lambda-box disregard the O2-sensor by unplugging the wire to the 15 degree switch? This is on a '80 SC with CIS. Background Earlier this fall I had a problem where the engine began to run poorly when reaching operating temperature. After some troubleshooting it turned out that the duty cycle went to 98% as the temperature went up. My suspicion was a faulty O2-sensor (or a temp related vacuum leak) so I wanted to disconnect it to see how the car ran without. Since the sensor has been removed by a PO and then reinstalled by me there is no connector in the engine bay that I can use to disconnect it. But, knowing that the system only goes to closed loop when the 15 degree switch grounds (right?), I figured that I could make it stay in open loop (thus, disregarding the O2-sensor, right?) by removing the wire to the switch (and covering the wire with some tape). That, however, did not make any difference. I eventually disconnected the O2-sensor by getting the O2-sensor wire out of the big black connector at the lambda-box which made the car run well again. I now have the time to do a proper troubleshooting but I'm still curious as to why the sensor still mattered with the 15 degree wire disconnected. Thanks for reading! /Björn |
CHT sender needs to be working. you also need to check control pressures and set the mixture for all this to work right.
if someone removed the O2, i dont see why they would remove the wiring or the connector it plugged into. |
The O2 sensor will improve your gas mileage. I am willing to bet that your problem was not the O2 sensor itself, but the O2 sensor RELAY. The relay is the silver cube that sits next to the ECU. It's a cheap fix.
The O2 sensor itself doesn't "ground". After it heats up, it produces a voltage in the range of .1-1V. This voltage indicates whether the mixture is too high, too low or just right. Remember that it is a narrowband sensor. It's basically a yes/no kind of input to the ECU.
When the O2 sensor is disconnected it runs in "open loop" which means that the ECU assumes a default duty cycle. As you're driving with the O2 sensor connected, the ECU is making slight corrections to the mixture based on the information received from the O2 sensor. |
Ketronic not Motronic......
Ty, You probably missed it. The OP has a CIS engine (Lambda) and no CHT. He has ECU not DME. Tony |
I guess it could be the relay but apart from the high duty cycle it runs fine, also I've ran it with a broken relay before and then it ran much worse. |
| All times are GMT -8. The time now is 07:43 PM. |
