Backfire?
When I test drove my car! 1980 911sc, it idled at 1000 rpm and had a little smoke due to the 40 degree weather, then it disappeared. The car drove great. I picked the car up the next day and put about 60 miles on it. The following day I put about 100 miles, everything was feeling great. Shift was good, no smoke, drove smooth. Later that night, I started the car, it was about 40 degrees out, the idle went to half and when I pulled out it backfired. And then the next day when I started it up for about 5 minutes I felt backfire again. The following day I let the car warm up, the idle was still at half, I let it warm up for about 15 minutes. When I went to drive it backfired, but then everything shifted fine. I am still feeling the backfire in the first shift. Once I hit 2000-3000 rpm I don't hear any more. Any thoughts on what would be causing these backfires? Thanks
Reiver
Sounds like your wur is not doing it's job.
When it is cool my wur raises my idle immediately for the first 20-30 seconds to about 1800 rpm. This is a euro SC but it should be the same.....this is all temperature dependent from the sensor. In warm weather it stays at normal idle. |
Nope!!!!!
It was your AAR that did the job of raising cold idle RPM not WUR. HTH. Tony |
backfired exaust or intake .
Reiver
Tony,
Ok, my mistake. |
