-   -   Permadoom question (http://forums.pelicanparts.com/porsche-911-technical-forum/780498-permadoom-question.html)
LCOX 11-08-2013 03:52 AM
Permadoom question
I've seen alot of negative comments here on the permatune cd units. Some calling them permadooms.
Also seen posts where they sometimes work only intermittantly as well.
My question: Is it possible for these 3 pin units to fire but to have a weak spark to the spark plugs?
john walker's workshop 11-08-2013 04:17 AM
all of the above.
faverymi 11-08-2013 04:18 AM
Wouldn't that be your coil instead?
I cut the losses and changed both. Coil and Box. They were 37 y/o I guess….
LCOX 11-08-2013 05:55 AM
Ok
Next question. On the permatune what should be the ohms readings testing it off the car. I think I've seen someone posting here on checking permatunes with a multi-meter but I'm not sure.
manbridge 74 11-08-2013 06:47 AM
Blue, black, or silver box? Potted or non-potted?
Some Permas are better than others IMO.
Adidas 11-08-2013 02:22 PM
Jeff. It's a blue unit. Have to take the cover off to see if it's potted or not. Which one gives more trouble?
timmy2 11-08-2013 04:21 PM
Have you tried Permatune's customer support? From what I've read they do a good job. No personal experience.
manbridge 74 11-09-2013 02:28 PM
This thread my help you.....
http://forums.pelicanparts.com/porsche-911-technical-forum/280168-permatune-question.html
larrym 11-09-2013 08:08 PM
i have an old early permatune 911 unit - it worked perfectly for almost 20 yrs on the 914-6 and is currently in my Manx
