-   -   MSD 6201 works - Tach no work & spark plug gap (http://forums.pelicanparts.com/porsche-911-technical-forum/780543-msd-6201-works-tach-no-work-spark-plug-gap.html)
hemmah 11-08-2013 07:14 AM
I installed a 6201 MSD on my 1969 911T and it works fine.
My tach is not operation and I read that is a common problem. I have read that connecting my black/purple tach wire to the distributor (MSD white wire) instead of the MSD gray tach wire will work. Thoughts? There is a diode provided with the install parts. Can this be used with the MSD gray tach wire to get my tach to work?
I set my spark plug gap to 1.45mm This is towards the high end of the gap recommendation. My drive seemed a bit sluggish but close to what I expected. Should I narrow the gap a bit? Suggestions?
Thanks,
hemmah 11-08-2013 07:31 AM
Oh
spark plugs are NGK BP6ES
I kept the original points
