bgyglfr's Avatar
Early S in disguise?
I just picked up a 68 911. I have a question about the vin. The vin plate shows as a 911L but the vin is 11805172. The fourth digit being a 0 should indicate it as an S. Anyone have any thoughts?
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 05:15 PM
Probably a typo for the S. I say this because the source I use indicates only 1267 S coupe cars produced in 1968, and your VIN indicates car number 5172--nearly 4K more than produced. L coupes range up to 5449, so your car would be in that range.
Where are you reading the VIN, 11805172? Is it the stamped VIN, located on the sheet metal just below the cover of the smuggler's box? Is it stamped on the plate by the latch for the trunk? Is on the plate on the door jamb by the hinges?
Pictures would be the greatest help. How did you determine it was a 911L? On the plate or by a VIN on the plate? The most reliable/least likely to be changed is the VIN by the smuggler's box. Again, a good clear picture of the VIN--the one by the smuggler's box and anywhere else--will be the best help for us.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-27-2013, 05:31 PM
bgyglfr's Avatar
The vin is the same on all of the plates. Smugglers box, door jamb and the plate. The reason for the confusion is the plate and the plate only says 911L. I am actually on my home with it right now so I don't have a pic to share yet. I'm not driving and posting btw. I have a buddy at the wheel.
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 05:36 PM
I edited my post as you typed. Look at the number of S cars produced in 68. Is your car a targa? If they transposed a digit, a 68 S targa could be 118 5 0172, with the 0 transposed with the 5 (which indicates an S targa.) Just a guess.
L.J.
Old 11-27-2013, 05:40 PM
bgyglfr's Avatar
I read that but I also read somewhere that the 5 in the 5th location would indicate a Karmann built car and I thought the fourth digit would have to be a 1 to make it an L? I think what you stated above makes the most sense though and it would obviously explain the L on the vin plate.
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 05:51 PM
bgyglfr's Avatar
It's a coupe.
70T 2.7RS spec.
68L coupe
bgyglfr's Avatar
Here's a link that I found.
www.elferhelfer.com/fzident/fzident68.htm
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 06:02 PM
Yes, a 5 in the fifth position could indicate a Karmann build but, afik, Karmann did not build the S or the L models. Just seems the simplest answer is a typo. Do you have the original engine and, if so, do you know the serial number?
L.J.
Old 11-27-2013, 06:05 PM
bgyglfr's Avatar
Don't have the engine or trans. I think it is likely an L. Am I wrong that the fourth digit should be 1 for the L though?
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 06:10 PM
You are correct, 1 indicates an L.
L.J.
Old 11-27-2013, 06:16 PM
bgyglfr's Avatar
Hmmmm. Maybe I should order a coa and see what Porsche comes back with?
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 06:19 PM
COA are notoriously unreliable. Before you do that, there are other places where numbers are found that can help. Under the dash pad will be a grease pencil number which should match the VIN. Also, behind the knee pad will be a production number that will help identify the chassis. Early cars had this production number match the VIN but later cars they were not matched but were recorded by Porsche to identify the car. Not sure if a 1968 production number would still match the VIN--others would know, however. Also, many early cars had the VIN written inside the door skin, and also stamped on the metal around the hole in the tunnel--by the grille in front of rear seats.
Keep us updated on what you find.
L.J.
Old 11-27-2013, 06:27 PM
bgyglfr's Avatar
Thanks so much for your help. I will do more digging as I get time. I am happy with it either way but if it turns out to be something special. That would be really cool.
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 06:36 PM
pors1968's Avatar
11805172 911L coupe us model w emission control
Old 11-27-2013, 07:15 PM
Bird. It's the word...
Fishcop's Avatar
^^^ This
It is a US delivered L. I had a similar moment when I bought 11805114
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-27-2013, 07:28 PM
bgyglfr's Avatar
Ok. Thanks for the help guys. Since there is no motor or trans it looks like the door is open for an R build.
70T 2.7RS spec.
68L coupe
Old 11-27-2013, 07:52 PM
pors1968's Avatar
easy to find a a 68 engine start 328 or 338 .
Old 11-27-2013, 08:04 PM
bgyglfr's Avatar
Here's a pic of the car as it sits now. In disguise in more ways than one. Anyone want a late model body kit? Lol
70T 2.7RS spec.
68L coupe
Old 11-28-2013, 04:48 AM
pors1968's Avatar
ok it need more than a engine and trans best luck whith your projet
Old 11-28-2013, 06:41 AM
Bye, Bye.
Scooter's Avatar
Ouch!!! That one hurt.
Elvis has left the building.
Old 11-28-2013, 08:07 AM
