Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
How to make pressure regulator shims...
... with a tuna can and a hole puncher.
Old 11-10-2013, 12:02 PM
Functionista
manbridge 74's Avatar
Ingenuous.
I wonder if it'd be worth finding some sort of stainless material.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-10-2013, 01:10 PM
76 911S Targa
You could probably also use stainless steel or brass shim stock relatively inexpensively. It comes in many different thicknesses. I am impressed by your innovation! Clever idea.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-10-2013, 04:56 PM
Banned
Yes, you probably can do it with other kinds of material, it's just that a can of tuna was lying there just opened, and I wondered if it would work...
The good thing is it worked, and helped solve some hesitancy issues caused by bad fueling. My system pressure was at the low end of the acceptable range (4.8), so I thought it was ok... but it wasn't. 5.0 is. So beware...
Old 11-11-2013, 01:59 AM
Functionista
Actually, with all of the iron and the fact that the shims are likely steel it shouldn't matter.
I think flatness is likely the bigger issue as the piston might wear on one side. Easy enough to hammer them flat, I suppose.
Jeff
74 911, #3
Old 11-11-2013, 06:38 AM
