77 Targa - SC flares or not
We are restoring a 1977 Targa (have the POA) with matching numbers. The car has been stripped to bare metal (glass out), metal finished, primed twice and blocked. It has SC flares. The correct engine is being rebuilt. The original paint is Platinum Metalic/W1, the interior is Beige/Tan leatherette. The only options are oil cooler front and Koni shocks. When I got it, it came with an anniversary "signed" steering wheel.
Questions are: Return to narrow rear fenders in back Stay with original colors Have an SC core that could be rebuilt and installed???? In California, the car is still required to have smog equipment: air pump, thermal reactors - if it was one year earlier - it would not have to pass smog. Any suggestions would be appreciated. Grant (santagrant@gmail.com 510 459-1168) |
Bye, Bye.
What is your goal? Retain value? Hotrod?
It sounds to me like you are interested in value. If this is the case, weld on the original quarters, install the original motor, paint original color, and otherwise bring it back to as stock as possible.
Elvis has left the building. |
not an easy chore
if you are repainting the car then put on standard flares, but it is not an easy thing to do as we are doing it on a 72 that had sc flares.
1975 911S Targa Silver Anniversary Edition |
Targa, Panamera Turbo
Could always wrap it instead of painting - actually much less expensive and some say it wears and looks better.
I like the wide body Targa FWIW...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Sugar Scoops Rule :)
I say take it back to original, if it's a numbers matching car.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Wow! I didn't realize I could get such a response in a short time. Thank you all.
