boss11's Avatar
Question adjusting rear ride height 82 SC
Hi guys, I need to find out what size spanner i need to turn the eccentric bolt on adjustable spring plate? it has been set to lowest setting by PO
my driverside rear corner measures almost 20mm lower than passenger side, it wasn't noticable when i had 16x6+7, i'd like to lift it so it doesn't rub on my 255/40 tires on 17x9 EM
i'll be looking at getting an alignment after, perhaps get a bit of negative camber dialed in to help with clearances..
does any one have alignment spec recomendations?
82 SC Targa Guards Red = Toy
04 E55 AMG Brilliant Silver = DD
04 Cayenne Turbo Platinum Grey on 22s = Previous DD
80 Wide body 12AT RX7 Black 350+ hp= Previous Toy
78 Alfa Romeo GTV Blue = My 1st Cool Car
Old 11-11-2013, 11:16 AM
boss11's Avatar
in above pics, the car has handbrake on which raises the rear when facing uphill, the rear is much lower on flat ground..
want to buy a spanner to adjust, but don't know what size....
Old 11-11-2013, 01:34 PM
1QuickS's Avatar
I measure 36mm on mine.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-11-2013, 02:15 PM
It is possible the height difference is due to corner balance adjustment. You might need to reindex the bars to fix your clearance.
Tony G
2000 Boxster S
Old 11-11-2013, 02:19 PM
boss11's Avatar
i really want to try adjusting spring plate first as it is at lowest setting
going to get a 36mm spanner and have a go
Old 11-11-2013, 03:34 PM
kjchristopher's Avatar
Pelican Parts - Product Information: PWE-2436RHW
Old 11-11-2013, 06:28 PM
boss11's Avatar
thanks Paul, 36mm did the trick
the tool in the above link would have been handy, but it takes weeks for gear to get to NZ, and I was able to go for a test drive last night
now i need a wheel alignment
Old 11-12-2013, 11:04 AM
