URGENT.... what sensor is this
What is this sensor...left side chain housing cover...http://forums.pelicanparts.com/uploa...1384289821.jpg
Thermotime switch for cold start system.
If you don't have carbs, you must be struggling to start the car. Oops - it's a 930. No carbs. |
Cold start switch that decides when the cold start injector needs to fire.
OK. Sorry 1974 carbed engine. OK. Thank you!!!
I am pretty sure I have one of those from my 83 SC if it is the same.
Make me an offer if it will work. Thanks mg |
He doesn't need it with carbs.
Just saw that.....that's why I have one!! I went to carbs last summer. I believe you can buy a plug from our host.
I don't use mine with my EFI system either... :)
| All times are GMT -8. The time now is 03:13 AM. |
