The turbo tie rods come with 2 gold washers. What are they used for? I'm assuming they are used as spacers on the inner side of the tire rod. But why would I want to use them? The turbo tie rods seem to be the same length as the stock rods without the washers.
Thanks. ------------------ Carlo Redmond, WA 1988 911 Carrera 3.2 1990 964 Carrera 4 |
good question. but that's where they're supposed to go. perhaps the threaded hole in the rack isn't deep enough without them. i've always used them, so i would imagine they're there for a reason.
Threaded hole on rack is not deep enough. Tie rod will seem tight but will work loose in time without the washers being installed. Also I used red locktight on threads of the tie rods.
Sounds good.
Thanks guys. |
