Spiderman
Jesse16's Avatar
ICV Question
Trying to "bulk up" an order to our host (filters, brake fluid, etc.) For my 87, thought I might include a new ICV on my parts shelf. Can anyone tell me whether there is a difference between these two parts ? 930-606-161-00-M114 and 0-280-140-501-INT Variously on other places I search, the less expensive one is listed as the replacement part for the more expensive one. Both are listed as Bosch parts, the first one (more expensive by 2x) is the part on the PET. The less expensive one seems not unreasonable to have on my shelf "just in case". There really isn't much to these things but if they start to fail or are intermittently bad, its difficult to diagnose.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 11-18-2013, 06:26 AM
Make America Great Again!
Rich Gas's Avatar
Easy to clean...seems like a catch all part for any idle related problems. I wouldn't add this to my shelf...if you're reaching for free shipping, add wiper blades, interior lights, fuel additive, parts cleaner, fuel filter, air filter, oil filter, gasket rings... Odd stuff like that.
Old 11-18-2013, 07:23 AM
Spiderman
Jesse16's Avatar
I hear you, I have what can best be described as a very intermittent issue so alternately, all I can really do as a hacker repair man is wait for more complete failure. My current ICV looks fine, checks out via all the available (home repair man style) diagnostics, even the 9V battery check. But, its is still a 27 year old electrical part. I have most of that other stuff on the shelf, laugh along with a voltage regulator, fuel filter, pump, plugs, etc.. (If I have one, I'll probably never need it, ie. "be prepared")
Old 11-18-2013, 07:33 AM
I recommend replacing it. I've done the cleaning thing, a couple of times,works for a little while.
Easy to replace,like you said...it is a 27 year old part.
Old 11-18-2013, 07:38 AM
Rich Gas's Avatar
Yeah, I guess just replacing it would do the trick. I had a problem with the brake booster T line by the cruise control. Used some black gasket repair goop and some shrink wrap. That seemed to clear up some of my ICV issues.
Old 11-18-2013, 07:47 AM
Spiderman
Jesse16's Avatar
Back to original ?? Any comments on those two part numbers. The Pet drawing on the expensive part actually shows the other part number alternately. Is it the same ? Big price diff for some reason.
Old 11-18-2013, 07:50 AM
Rich Gas's Avatar
Weird, looks like the same part, both made by Bosch. One says OEM. Buy the less expensive one (not cheaper).
Old 11-18-2013, 08:10 AM
gtc gtc is offline
abides.
gtc's Avatar
They are the same part. You are paying an extra $140 for the Porsche part number.
Graham
1984 Carrera Targa
Old 11-18-2013, 08:23 AM
Spiderman
Jesse16's Avatar
Was kinda hoping that was all it is. I'll get my order together and move forward, thanks.
Old 11-18-2013, 08:37 AM
