Yes that is Pasha cloth
redstack's Avatar
Weak eng cover spring
I have an 84 with not just a Tea Tray tail, but also it has the A/C condenser in the tail. The resulting weight is too much for the release spring. When I pull the release, you have to have a second person lift at the same time to get it to release.
I have tried stretching the spring a bit, with no luck. Is there a way to install a double spring or a newer stronger one? I don't expect miracles like having the cover jump up, or even for the poor hyd struts to work, I just need to get in the engine compartment by my self.
Old 11-15-2013, 08:37 AM
Try realigning the spring latch... guessing that it's binding a little.
The spring is strong enough to pop it up, even with the tail and condenser (light weight).
Old 11-15-2013, 04:47 PM
