jluetjen's Avatar
Question Torsion Bar Dimensions
I'm trying to calculate the spring rates for the different early (Pre G50) 911 T-Bars. Does anyone have any near by from which they could take a couple of measurements for me?
What is the "working length" (excluding the fluting) for a front and a rear T-bar?
The math is pretty straight forward and I'd be happy to post the results after I figure them out.
Thanks!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 06-07-2002, 07:22 AM
I have a spring plate angle calculator on my site - http://vintagebus.com/cgi-bin/spring.cgi - plug in your t-bar size and weight, and whammo, out comes the spring plate angle. Set your unladen spring plate to that angle using a protractor, and you're good to go.
The math credit goes to Will Ferch - I just did the programming and hard-coded the trig tables.
Here's the t-bar data:
mm:lbs
23:100
24:120
24.1:122
25:140
26:165
27:191
28:221
29:254
30:291
31:332
32:377
33:427
Old 06-07-2002, 07:51 AM
Screen Shots
Old 06-07-2002, 07:55 AM
jluetjen's Avatar
Thanks Tom!
Now how about the front bars????
John
'69 911E
Old 06-07-2002, 10:56 AM
Maybe Will has some data on them - I don't.
Originally posted by jluetjen
Thanks Thom!
Old 06-07-2002, 11:16 AM
jluetjen's Avatar
Duh! I'm sorry Thom!
John
'69 911E
Old 06-08-2002, 04:34 AM
Guys:
Sorry for the late response:
Front torsin bars, ....given first in mm diameter..then lbs/in rate
18.8 = 110
21 = 173
22 = 210
23 = 250
24 = 296
25 = 350
Don't know if sizes greater than 23 are even available.
--Wil Ferch
Old 08-21-2002, 07:59 AM
