Hey all,
Well for the first time in my life, I actually took off all the brakes by myself on a 911!! Wooohooo!! Sorry I had to share to joy...see pics of the car. I basically put new Zimmerman drilled rotors, Mintex pads, rebuilt the calipers (painted them red..sorry had to!), and put new stainless steel lines. Now here's my question. Before I took everything off, I was under the impression that I had Boge shocks in the front and the crappy "M" calipers. To my surprise, after cleaning 30 years of grime, I saw that my shocks were Konis and I have the 3.5" spacing "A" calipers..and from what I understand that's really good news correct?? So now if I wanted to upgrade my brakes later, what are my choices? I can't afford Big Reds, so what are the different options as far as discs/calipers? On the suspension side, do I have to replace the Koni inserts with Konis only? Any recommendations there? Thanks for all the help! --Michael
Michael,
Unless you want to replace the entire strut asssembly ... yes, Koni 's are the required replacement. Your rotors ... which I assume won't need replacement very soon, can be replaced with the 24 mm thick '84-'89 Carrera rotors, and 'wide A' calipers. And, 32 mm Turbo rotors and calipers are another option!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren,
Thanks for the info. When you mention Turbo brakes, what year are you talking about? Or will any 77-89 Turbo work? Will I need to change the hard lines connecting to the calipers? Also how about C2 or 993 calipers/rotors, will they fit? Thanks, --Michael |
SCWDP- Shock and Awe Dept
Looking good Michael! Are you planning on having her back together for Sunday? I hope to you there.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Thanks Ryan,
Been waiting for over a month for my mechanic to put in my 993 TT oil cooler before I can go anywhere. If he can do it before Sunday I'd love to be there...if not I'll be at the next get together! --MIchael |
