Drivers door rattle?
My 76 Targa drivers door is starting to rattle when I go over bumps in the road. it closes firmly with the typical 911 thud and doesn't seem to move when I pull firmly on the door handle. Any ideas what to look for?
1976 911 Targa 2.7 CIS Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior 1963 356 SC- crashed ![]() 1962 356 C- sold ![]() 1965- 912- sold- fun but too slow |
Window tracks
I've driven alot of crap to get here man! |
Thanks, do you know what needs to be done to fix the problem?
Start by removing the interior door skins and see if anything is loose in there. In my case it was just tightening up a couple bolts. Later on the windows started rattling all that was needed was sliding new felt inserts into the rail.
Perfect, sounds fairly straightforward.
Can also be the linkage rods in the door locking mechanisms. They run through an assortment of rubber and Nylon guides that dry out and wear over time.
I pulled the entire window mechanism out of one side (so far) , cleaned greased and replaced all the felts and rubber wipers. Works like new now. Very easy to get the door latch hardware out once the window is out of the way. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
930T Owner
My mirror came loose where it bolted to the door. Pretty easy to check. Might want to rule that out.
Chris.
Hams930T 2017 Turbo S |
Reiver
I also found some old bits from the door strap being replaced...a bolt rattling around only when bumpy etc.
Obsessed
Door lock rods in my '75 were making and awful racket. The door panels off and back on is a tedious pita, be prepared to clean, grease, tighten everything while you are in there. Good time to replace those window seals while you are in there if it needs them.
Travis, sent from my Galaxy S3
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
Thanks to everyone, I appreciate the feedback!
Matt
It could also be the anchor point for the windows helper spring. When I picked up my 83 there was a rattle in the door. Turned out to be this anchor point which looks like a short piece of rod stock with a slot cut in the end that the spring hooks into.
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
