Targa_PB_78_SC
mike sampsel's Avatar
Rear main seal oil leak?
After 4,000 miles since rebuild, I’m down my “final” oil drip. Thought it might be coming from the case or the forward stud, so I applied some (generously) Dow Corning 111. The oil looks dirty so it’s likely dripping of the front of the case? Oil is fresh some 6 months ago.
I’ll get some photos of the case when my endoscope charges.
Any ideas, and if it is the rear main seal, any harm in leaving it be? The triangle looked pristine when I last checked and I didn’t see a trail of oil from on high.
BareRearedRookie
Old 04-24-2023, 02:11 PM
Mainshaft seal maybe?
206 637 4071
Old 04-24-2023, 03:01 PM
Does it smell like gear oil?
Isn't Dow Corning 111 a silicone lubricant, not a sealant?
Old 04-24-2023, 08:38 PM
Targa_PB_78_SC
I don't think so on the smell, but I can check again.
111 is not a sealant, but I thought it would yield a clue if its weeping from the rear stud or the case. Based on no to little change with vs without the 111, I'm assuming (perhaps incorrectly) its not seeping from the case seam or the stud.
Difficult finding oil behind the exhaust crossover pipe too.
BareRearedRookie
Old 04-25-2023, 06:04 AM
Targa_PB_78_SC
John,
There is definitely some grime up at the hole between the engine case and the trans.
Makes me believe it is likely the mainshaft seal. Given it is, as long as I do not let the oil level get low, the harm seems minimal to leave it as is a while?
Other than I wanted a drip free rebuild . Oh and the small of the oil getting on the crossover exhaust.
BareRearedRookie
Old 04-25-2023, 07:56 AM
proporsche's Avatar
Mike..it is really possible that your trans.t/o bearing tube is leaking -- just a guess now until you clarify if it is engine or gear oil.On the tube is a seal plus little O-ring many people do not know-or do not replace this one...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-25-2023, 08:09 AM
Targa_PB_78_SC
Ivan
Hi Ivan,
I does not smell like gear oil.
The transmission was rebuilt by a pro at the same time, hope he replaced said o-ring. I'll double check the smell again. I do not want to get low on gear oil and not know it!
Update: Trans build list has a 999-701-359-40; 915 T/o Sleeve o-ring charge for $3.65. So I'll assume it was definately replaced.
Oh and the seal I used was an Erling, did not use the one which came with the gasket set.
BareRearedRookie
Old 04-25-2023, 09:44 AM
proporsche's Avatar
Originally Posted by mike sampsel View Post
Hi Ivan,
T'hanks
That what i thought ,the work was all done by pro....but lets say the supplies of seal is questionable...personally i do not like V.R.engine gasket sets mainly the crank seal .I only use either porsche or black trimmed Elring....ask your tech what he used?
Ivan
Old 04-25-2023, 09:48 AM
Use a black light on the drip. Some trans fluid fluoresces while engine oil doesn't unless you add dye.
Old 04-25-2023, 10:18 AM
Targa_PB_78_SC
Ivan
I did the engine, used the Erling seal, not the VR supplied one. Will see if I can find a black light. If it is the crank shaft seal, is it a serious enough issue to get fixed right away?
BareRearedRookie
Old 04-25-2023, 12:48 PM
Targa_PB_78_SC
Anyone know if Kendall florescees?
BareRearedRookie
Old 04-25-2023, 12:50 PM
proporsche's Avatar
well.if it the crank seal you will be annoyed by the smell as you can tell it drips on the cross member
a lot of peeps drive with this leak but i`m sure you would not;-)
ivan
Old 04-25-2023, 12:51 PM
Targa_PB_78_SC
Humm, I wonder if there is a “worthwhile” flywheel upgrade. This might make the effort to get to the crank seal more liked. Suspect the stock flywheel is hard to beat though.
BareRearedRookie
Old 04-25-2023, 03:10 PM
Mike, when you pull the flywheel, I can’t recall telling you to JB weld the end plugs of the oil gallies.
There is 3 plugs behind the flywheel. I chased a leak there in the past.
Bruce
Old 04-25-2023, 05:00 PM
Targa_PB_78_SC
Bruce
Thanks Bruce,
Looks like you thought to tell me.
BareRearedRookie
Old 04-26-2023, 03:55 AM
proporsche's Avatar
Mike is it me or not, I do i see the seal too deep inside?
It should be flush with the case
Ivan
Old 04-26-2023, 09:41 AM
proporsche's Avatar
like this Mike i just finished 1982 engine
Old 04-26-2023, 12:05 PM
Targa_PB_78_SC
Ivan
Ivan,
Ouch, so maybe I pushed the seal in too far? This is the only pic I have.
BareRearedRookie
Old 04-26-2023, 01:38 PM
Grappler
Rodsrsr's Avatar
Use factory Porsche seal, flush with the case.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 04-26-2023, 03:17 PM
Targa_PB_78_SC
Ivan,
This is the Porsche seal?
Do you prefer it to the Erling now?
And if I replace the seal, is there a recommended sealant for the case seam, in case it's oozing?
Mike
BareRearedRookie
Old 04-27-2023, 04:25 AM
