Banned
stuck cluch
I have a 912 that has been sitting for 20+ years, the clutch wont disengage... The cable moves the arm but nothing happens inside. What can I do to break this free with out removing the engine?
Jack the car up so he rear tires are of the ground and support with jack stands. (or raise on a lift) Start the engine with the trans in a higher gear and let idle with the clutch held to the floor with a stick. You can sit in the car and hold it in but sometimes it takes longer for the clutch to break free then you want to sit and hold it. The chattering of the tires and trans will break the clutch free. I've had it take up to 20 or 30 minutes but it has never failed me yet.
Project Addicted
Same as above almost....
Get it running, Rear wheels off the ground, put into high gear, push in clutch hit the brakes. Disc should break loose.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
