| johnman001 |
11-27-2013 07:25 AM |
These suggestions presented here are close. When I align them with my alignment machine, the first settings I perform are Caster (move the tops of the struts as far back toward the rear of the car as possible), then I set them the same. Spec calls for approximately 6° (going off of memory). Then I set camber (moving the tops of the struts toward the center of the car). Again, I see what the machine says and make them equal. Since both of these adjustments have an effect on TOE, I perform the TOE adjustment LAST. Once done, I re-run the swing program and check (and more times than not, make some final small adjustments).
This of course MUST be done AFTER corner-balancing or altering ride height front or rear since that also effects Caster/Camber/Toe. Once lowered, many of these cars may not be able to achieve factory Caster/Camber numbers without altering the car or suspension. The upper strut mount holes in the body can be ground larger to a point and the upper strut mounts can be changed out to achieve more negative camber. Also, if the rubber bushings in your front suspension are no longer round or are deteriorated, they may need to be changed before your car may be able to be brought back into spec.
Before any specific suggestions can be made, the printout information should be located and posted. Otherwise, try to make all the settings side-to-side equal.
