Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
And you think burning oil is a problem...
My car BLOWS oil out of the exhaust.
Don't ask me how. I don't have the answers. There is literally oil all over the rear decklid above the pipes.
It goes through oil pretty quickly.
The end, it is nigh.
I'm sure at this point, the car must be in contention for some kind of "Can't kill me B!tch!" award.
-kb-
Old 09-02-2002, 12:47 PM
makaio's Avatar
How many miles per quart added are you getting?
Old 09-02-2002, 01:41 PM
CamB's Avatar
You're not overfilling it with oil? Just checking.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 09-02-2002, 01:56 PM
Early_S_Man's Avatar
Porsche Crest
Kurt,
I assume you haven't read all of the recent posts about smoking on startup. oil dripping out the exhaust pipe, etc???
Assuming that your engine isn't laying down a smokescreen while running ... there are other ways for the oil to get to the exhaust system without being burned in the combustion chamber ...
Engine smoking...then fine...whassup?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-02-2002, 02:20 PM
Brian993's Avatar
Kurt-
I think what you have here is the curse of the ricers. Voodoo!! Every time you squash a ricer your car gets closer and closer to the curse. Bad enough they laugh at your paint now they will be rolling in your smoke and oil.
http://www.p-caronline.com/directory/brian993
Old 09-02-2002, 02:55 PM
It doesn't smoke at all.
But i can't otherwise explain oil ALL OVER the deckid.
Okay...maybe it's just leaking so badly it's a small oil station.
-kb-
Old 09-02-2002, 03:13 PM
A Quiet Boom's Avatar
Kurt I had a bad leak on one of my oil lines on my old engine, I had to clean my ductail every other day to get the oil off. I didn't figure out the leak until I steamcleaned the engine since it apparently only leaked when hot.
Old 09-02-2002, 08:55 PM
Interesting quiet, thanks for the top! Mine does leak a lot too.
-kb-
Old 09-02-2002, 10:34 PM
