Thanks for all the tips. It's been cold and snowy/icy lately, so I haven't driven the car much. I did replace the flywheel sensors and had a chance to get the car good and warm and go for a nice hard test drive.
The dramatic powerslide I did while turning right on the little highway on-ramp would suggest that the problem is resolved. So far, the sensors do seem to have been the culprit. |
If the problem returns, change out your fuel pump relay. Had this similar issue once before, turned out the relay had broken solder joint and would exhibit cutout in a right hand turn.
| All times are GMT -8. The time now is 10:47 AM. |
