Jig for testing straightness of struts?
Hi -
I was wondering if anyone has built a jig for testing struts for straightness? I found this older thread that has photos of a factory tool which is pretty cool looking (see attached), but likely NLA and/or crazy expensive... http://forums.pelicanparts.com/porsche-911-technical-forum/615761-strut-bent.html I could probably fabricate something similar to the factory jig, but I don't know what any of the angles need to be etc... Anyone done this or know what the angles should be for a straight strut? Thanks, Tom http://forums.pelicanparts.com/uploa...1385574816.jpg http://forums.pelicanparts.com/uploa...1385574858.jpg http://forums.pelicanparts.com/uploa...1385574899.jpg |
Looks like you could just enlarge the picture and get the angle right off of it. With the axel flange level (set the Electronic Digital Protractor at 0)you should be able to run an Electronic Digital Protractor up the strut and see if the readings remain the same thru it's entire length to see if there is any bend. I think this would be an easier solution than building a jig. ( just a thought)
Are you having alignment issues? Bent struts do happen. It's difficult to accurately measure the spindle included angle.
Do you have the struts off the car? Some body repair shops have a jig, like and alignment jig, that can be used to straighten struts on the car. I have successfully straightened a bent strut using a very large, securely anchored vice, to clamp the spindle. I clamped the brake mounts in the vice and used a very long stiff bar in the strut tube to bend it back straight. Once you are SURE they are straight you may want to consider welding in reinforcing gussets to prevent further bending. |
I was always told if there is cracks in the paint around the spindle its probably bent
Thanks, Tom |
In your situation I would definitely want to verify the struts as being straight. Being off the car it should simplify things. My experience is the tube above the spindle can be slightly bent, but it will not be obvious by casual inspection.
The best I could do was use a machinist's protractor to measure the angle. I'm sure there must be a better way. Hopefully someone with more experience than me will chime in. |
Found some photos of more cool suspension parts jigs. Anyone have these or have access to them?
Thanks, Tom http://forums.pelicanparts.com/uploa...1386553373.jpg http://forums.pelicanparts.com/uploa...1386553390.jpg http://forums.pelicanparts.com/uploa...1386553433.jpg http://forums.pelicanparts.com/uploa...1386553450.jpg http://forums.pelicanparts.com/uploa...1386553468.jpg http://forums.pelicanparts.com/uploa...1386553482.jpg |
besides a bulge (as pictured on the other thread) or cracked paint...
if the strut insert can be removed and reinserted with no problem, can that be used as a test for straightness or integrity of the strut (the strut housing)? |
I,m not an expert as I,ve only seen this a few times . The usual symptom of a bent strut is an alignment issue where you can,t get close to the same camber setting on one side compared to the other. (with the car known to be level side to side. It could be the body bent or sagged or the strut (weaker part) is bent. Most likely from a collision and likely on only one side. Usually if it,s bad enough to replace you can see the bend ,bulge or dent with a careful visual examination. A straight edge along the tube might help identify a problem also. They always bend above the steering arm because the lower part is reinforced and shorter below the spindle. I,ve never tried to straighten one, only replaced them with a good used one. The shock shaft could also be bent inside the tube and would only affect a camber change at droop vs at normal height. When you see the camber side to side problem you need to check everything until the damaged parts are found and the difference explained. Chuck Moreland Elephant Racing must have a jig made so he can raise and weld spindles. He would probably charge nominally to check one for straightness. |
It must cost a million dollars for all the special tools and jigs Porsche has. No other car has as many special tools as Porsche (perhaps Ferrari but I,ve never worked on one.
Many of the special tools can be substituted with some good pullers etc. Gone are the days you could rebuild and align a car with vicegrips, a level, and a piece of string. (well almost) |
I've not seen the factory tools in a very long time, back at the dealership (mid-70's). :)
We use the milling machine table, protractors, and other measuring tools to see if a spindle, steering arm, or strut tube is bent and compare the values with a brand new strut. |
I have most of the old factory tools from 1950's through 1980's. http://forums.pelicanparts.com/uploa...1386562747.jpg http://forums.pelicanparts.com/uploa...1386563230.jpg |
P286b Strut jig, 911/912/914-6 from 1969-on. http://forums.pelicanparts.com/uploa...1386566389.jpg http://forums.pelicanparts.com/uploa...1386566439.jpg |
P288 Transverse control arm jig, 911/912 from 1965-68. These tools and fixtures were very well made, considering their limited use. http://forums.pelicanparts.com/uploa...1386749056.jpg http://forums.pelicanparts.com/uploa...1386749104.jpg http://forums.pelicanparts.com/uploa...1386749141.jpg |
Hi Jon,
Thanks for posting! I think these original factory tools/jigs are so neat. It's nice to know that they are still out there and being used very now & then. Short of finding some for sale somewhere (which seems pretty unlikely!) I will go Steve W.'s and try to compare know good parts w/suspect parts using more medieval methods and materials - straight edges, protractors, rulers etc.... Thanks, Tom |
If my front end aligns ok, does that mean I don't have to worry about a bent strut?
That depends. What exactly do you mean by "OK"?
A friend of mine just had his '71 aligned. The mechanic was able to get about 1 deg negative camber on both front wheels. When you looked in the trunk at the tops of the struts, both were all the way to the left in their towers. (when looking from the front). One of his struts was slightly bent. His alignment was OK, but not ideal. |
Jon is quite correct. What I think he does not emphasize enough is that while adjustments can be made to correct for a bad strut during an alignment to allow a car to drive forward, as soon as the car has to turn the geometry can fail unpredictably and rapidly deteriorate. This is not something wanted in a Porsche.
| All times are GMT -8. The time now is 10:46 PM. |
