Little blue packet in clutch kit...?
So I replaced my clutch and after I got the clutch on, transmission/engine together, and in the car, I picked up the box and this little blue packet fell out... I'm assuming its grease, where does it go? and I need to take the transmission and engine out again don't I? /: dammit!
Old 11-27-2013, 09:03 PM
Banned
It's probably grease that is meant go on the guide tube for the release bearing (so it slides more easily on the guide tube and doesn't bind). People have had success spraying lithium grease (spray you can get at hardware and auto parts stores) on the tube from the inspection hole in the bell housing.
Old 11-27-2013, 09:37 PM
Grease for the splines on the input shaft.
Old 11-27-2013, 10:06 PM
so drop and disassemble?
Old 11-27-2013, 10:22 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Post 2 is an option...
Who Will Live... Will See
Old 11-28-2013, 02:07 AM
thumbdoctor's Avatar
Pilot bearing and spline grease. If you operate the car in a corrosive environment the clutch plate hub may hang up on the dry splines of the transaxle input shaft and possibly cause a launch shudder.
Porsche, aucune comparaison
Old 11-28-2013, 04:29 AM
