-   -   What is this engine "plug" ? (http://forums.pelicanparts.com/porsche-911-technical-forum/784230-what-engine-plug.html)
Deschodt 11-27-2013 04:39 PM
Sorry if this is a beginner's question, but what's this plug seen below in gold (left?)
http://forums.pelicanparts.com/uploa...1385598913.jpg
I've looked at a few 911 engine cases today, most have it case color, not gold... It does not appear to be removeable (by me anyway)... One car had what looked like JB weld over that area... No cracks at all in the case around it, so, guessing that can leak ? The odd part is the JB welded one was a complete motor, fresh rebuild, case split by a reputable shop. So what do you think the deal is ? Precaution or something afoot ? It's was not leaking...
cgarr 11-27-2013 04:53 PM
Machining plug, most will cover them with jb weld to help from any oil seepage.
Deschodt 11-27-2013 04:59 PM
Thank you. So not a disqualifying feature on a rebuilt engine where case was split, then ?
cgarr 11-27-2013 05:18 PM
not at all, the original may have looked suspect or when I do major case work all the plugs come out so it can be cleaned, pretty much sop.
Deschodt 11-27-2013 05:24 PM
Great, good to know. Thanks a lot Craig !
rattlsnak 11-27-2013 10:48 PM
Isn't that where the relief spring and spacer go into?
Deschodt 11-28-2013 05:14 AM
No, that's on the other half of the case. This is a plug flush with the case. Looked useless. Machining plug makes sense. If ever noticed them until I looked at a clean case :-)
