Problem when itīs running warm.
Yesterday I took my 930 to the Porsche mecanics and they fix my mixture, I test the car and itīs run totally ok.
Later when I was driving home the idle went up to 1800 rpm. So the idle goes up when the engine is running warm, when engine is cold the idle is normal. I now it has been a lot of Idle question on this forum but I havenīt seen anyone like this. So my hope is in your hands guys, itīs a cruising tomorrow but its not that fun to cruise with an idle on 1800 rpm! "Hope someone can help me" /J |
J-
Does the turbo have a decel valve? Had a similar problem recently, unplugged the vacuum line from mine, and the problem went away....too cheap to replace it :) cheers -Brad 80SC |
| All times are GMT -8. The time now is 08:39 AM. |
