-   -   Help with Cert of Authenticity (http://forums.pelicanparts.com/porsche-911-technical-forum/784372-help-cert-authenticity.html)
kiwi 911 11-28-2013 10:48 PM
If I gave you these numbers
Chassis number is WPOZZZ99ZSS310609.
Can sometime tell me the spec this car left the factory??
Paul
Flat6pac 11-29-2013 04:14 AM
You have to contact Porsche AG for the certificate.
Bruce
javadog 11-29-2013 05:16 AM
First off, that's an invalid VIN. Check the numbers and letters and repost the correct VIN. For example, your 3rd digit is an O, not a 0.
Secondly, what are you trying to determine? Market that the car was built for (spec)? Options on the car? What, exactly?
What does any of this have to do with a COA? Do you have one and you are trying to verify its accuracy? Don't have one, and you want the info for free?
Do you own the car? Is there still an option label on it somewhere?
JR
S2GART 11-29-2013 07:03 AM
I assume you are not from the U.S. That VIN# is not a U.S. vin. Looking at The Red Book, your car was made between Aug '94 and Jul '95 and based on the vin # you gave I am guessing it was made in Oct-Nov '94.
Other than that, nothing more could be told about your car without contacting Porsche AG. As asked by Javadog, when you say "Help with Certificate of Authenticity" are you saying you have one and need help with it.....? If you do indeed have a COA, what you see is what you get.
tholyoak 11-29-2013 09:43 AM
With the newer cars, most of the info that would come on the COA is stored in the Porsche PET program so you can get it from any dealer. For instance this is the info that comes back on the VIN above:
1995 Carrera 993 Coupe,
trans type G50.21
engine type M64.05
order type 993331
Option Codes (didn't include the descriptions here as it was too much typing)
I210, I233, I323, I434, I604, M130, M150, M197, M219, M288, M325, M335, M338, M398, M423, M425, M437, M438, M441, M455, M480, M492, M534, M544, M562, M566, M567, M573, M605, M650, M651, M657, M685, M939, M975, M982
Option M325 is interesting, version for South Africa/New Zealand.
In the USA/Canada if you call PCNA they will tell you everything that would come on the COA if you provide documentation of ownership free of charge. You only need to pay for it if you want the fancy certificate.
Todd
ClickClickBoom 11-29-2013 10:02 AM
Originally Posted by tholyoak (Post 7781238)
M325,
Todd
"Kiwi 911" ......
azzarule 11-29-2013 05:03 PM
ha ha ha ha.
Sorry couldn't resist. But maybe someone doesn't know what a Kiwi is.
JJ 911SC 11-30-2013 03:35 AM
http://forums.pelicanparts.com/uploa...1385811353.jpg
kiwi 911 12-01-2013 01:56 AM
http://forums.pelicanparts.com/uploa...1385891716.jpg
Not quite - that's the kiwi fruit, the kiwi is New Zealand's national bird..........
I will make contact with Porsche tomorrow.
